Welding Shop
Arnasteel
this thread has 9 replies and has been viewed 1507 times
Old 12-05-2014, 08:54:51 PM
cammer cammer is offline
Default Arnasteel
i have a old shot gun from my dad and i want to give to my grandson but my idiot brother backed over it years ago while hunting with his buddies broke a piece it,s made from armasteel i am trying to find what filler rod to tig it with any ideas. thank,s
Old 12-05-2014, 09:21:14 PM
ChrisinEstes ChrisinEstes is offline
Default Re: Arnasteel
I'm not sure if it's the same Armasteel or not, but, General Motors developed a cast iron alloy for automotive engine & drive train parts they called armasteel. I have a couple Armasteel stamped Pontiac crankshafts. Maybe that will point you in the right direction.
Speaking of Pontiac, your username, cammer, is that Pontiac OHC 6 related?
Chris
Old 12-06-2014, 12:28:00 AM
Default Re: Armasteel
sorry i hit n instead of m cammer refers to 427 sohc FORD no steenken gm will be found here
Old 12-06-2014, 02:57:07 AM
Fifty7ChevyNut Fifty7ChevyNut is offline
mr cammer,
fastest two fords i ever saw:
first one was powered by small block chevy, the other one was on a GMC rollback.
chevy and fords are like johndeere and international.
don the nut
Old 12-06-2014, 10:37:28 AM
Before you think about welding any pressure bearing or critical part of a firearm I would run the idea past a QUALIFIED gunsmith. Many "old" shotguns are at or beyond their pressure limits when using modern ammunition, and anything that would further weaken them could prove extremely dangerous, so play it careful and don't become another involuntary accident statistic. Regards,
Combustor.
Old 12-06-2014, 11:34:29 AM
Well, I was close-ish... I had the SOHC part of it right.
I agree with Combustor too, if it's a critical part, you should find a grey-haired gunsmith to at least look at it.
Chris
Old 12-06-2014, 11:55:20 AM
this is the very back that the stock screws to. i have been drag racing for 55 years with 427 ( FORDS ) i have heard it all from you follow the heard never had a original thought guys with book from gm gumball machine part dispenser. with fe fords you have to use your brain to make them run not just write a check i enjoy a challenge. chevrolet stands for . cranks-hard-every-valve- rattles-oil-leaks-every-time .ford stands for. fierce-ornery-rugged-dependable. ____ing -old-recycled -dodge. flip-over-read-directions.first-on-race-day.backwards driver-returns-on-foot-found -on-road-dead.please use your own brain come up with something new. SS/B 9.00 147mph
Old 12-06-2014, 12:03:12 PM
mcostello mcostello is offline
Don't forget- Forked On Race Day.
Old 12-06-2014, 12:22:29 PM
You forgot For Off Road Dependability!
Whew... Lucky for me I have a "Professional Grade" GMC! Let's see... Gay Mans Chevrolet... Gotta Mechanic Coming...
I've never come across one for Chevrolet... I'll have to try to remember that.
Chris
Old 12-06-2014, 12:26:32 PM
i did not hear it until i was 60 pass it on
