IH Cub Lo Boy
this thread has 5 replies and has been viewed 427 times
Old 07-18-2019, 02:11:59 PM
VicF VicF is offline
Default IH Cub Lo Boy
Hi, I've had some issues with starting my IH Cub lo boy. It's getting gas but getting no ignition. I'm going to replace the coil and spark plugs. Is it necessary to remove the gas tank hood assembly to change the sparks plugs? It seems that there isn't a lot of clearance. Thanks
The Following User Says Thank You to VicF For This Post:
Old 07-18-2019, 03:50:35 PM
Sonny Reese Sonny Reese is offline
Default Re: IH Cub Lo Boy
File or replace the points and your good to go!!---I have 8 of these tractors and every time I go to use one, gotta file the points!
Plugs can be changed without taking the hood off, BUT it's much easier to get in there to them. Be real careful not to break the plugs off!-----It's common to have them break off in these engines. They are the C-60 engine, and most of them use Champ. D-15, or equiv. plugs thanks;sonny
The Following 2 Users Say Thank You to Sonny Reese For This Post:
Old 07-18-2019, 04:41:52 PM
EdDarowski EdDarowski is offline
I'd change the points and condenser. Lightly file the new points, as they sometimes have a coating on them. Plugs can be changed without removing the hood, as Sonny said, but it is tight.
Ed
The Following 2 Users Say Thank You to EdDarowski For This Post:
Old 07-18-2019, 05:56:40 PM
When points are oxidized filing them will get it running, but if t he points aren't removed and buffed the corrosion on the sides will soon migrate back to the contact area. A thoroughly cleaned set is as good as anew set.
The Following 3 Users Say Thank You to J.B. Castagnos For This Post:
Old 07-18-2019, 06:35:11 PM
Unless they are pitted or worn.
Ed
Old 07-18-2019, 10:14:44 PM
I have three cubs. Two cub lo boys and one farmall cub. They were my Fathers and he’s been using them for over 30 years. Never had an issue with points. Ill give it a try though. Thanks for the help!
