John Deere 40: would you put the correct tires on?
this thread has 6 replies and has been viewed 359 times
Old 07-23-2019, 12:34:16 PM
mtb020184 mtb020184 is offline
Question John Deere 40: would you put the correct tires on?
So My grandfather who also collected and hobby farmed bought this JD 40 a while back at on auction. It was on a sod farm, and they pulled gang mowers, and the flail mower that is on it it the picture with it. The apparently put the bigger tires (and turf tires) on it so it wouldn't damage their crop. When he passed away I inherited the JD40. I would like to do something with it someday, it's rough but easily workable.
The question is would you put it back on the original sized tires (I think the rims are the correct rims) or leave it as it was being used last, on the over-sized turf tires?
Old 07-23-2019, 12:39:55 PM
casertractor casertractor is online now
Default Re: John Deere 40: would you put the correct tires on?
Are you going to work or show this tractor or both?
www.millertire.com
Old 07-23-2019, 12:52:00 PM
Both maybe, probably not work it to much, so more show. I was thinking current tires on is more "working clothes" look.
The Following User Says Thank You to mtb020184 For This Post:
Old 07-23-2019, 01:08:44 PM
Thumbs up Re: John Deere 40: would you put the correct tires on?
It does look like a brute with those big tires on it!
Old 07-23-2019, 01:17:13 PM
Haha yes it does!
Old 07-23-2019, 05:09:17 PM
Phil Johnson's Avatar
Even if you restore it, I would leave it with the tires and equipment that's on it.. It would stand out more at a show and look a little different than all the other 40's that would be there!! After all, that's part of it's history!
The Following 2 Users Say Thank You to Phil Johnson For This Post:
Old 07-23-2019, 05:17:22 PM
I seem to recall those original sized tires being hellishly expensive
John Deere D Tires turnwaldw Antique Farm Tractors 7 03-15-2016 08:24:51 AM
John Deere model L tires Dave R Antique Farm Tractors 3 12-17-2013 11:48:11 PM
John Deere LA Tires dadam2308 Antique Farm Tractors 7 03-22-2013 08:48:49 PM
John Deere & John Deere Bain horse drawn mowers Amosalmo Horse Drawn Equipment 4 05-18-2012 11:35:01 AM
John Deere A and John Deere R For Sale (Stuck in the snow!) Gary Biewer Antique Farm Tractors 11 01-25-2011 06:33:52 PM
