Pow'r Pup Power pup with Wisconsin AK
this thread has 8 replies and has been viewed 440 times
Old 08-06-2019, 09:47:49 AM
CaptAndy CaptAndy is offline
Default Pow'r Pup Power pup with Wisconsin AK
Hi team, requesting help identifying "clutch" (my guess) on this pow'r pup tractor. Pow'er pup im being told was order form Popular science magazine and put together like a kit/model.
SO from my Wisconsin engine has a pulley. this pulley is connect to shaft that runs back to tranny. This pulley goes upward about 12 inches and connects to another pulley and goes through this mechanism "maybe a centrifugal clutch" and to the back side using a chain sprocket. Then the chain goes back down and connect to the same shaft that comes off back of engine.
My thought is you throttle down which stops the chain driving and allows you to switch gears and then you throttle back up to kick in the "centrifugal clutch" (tag on this unknown device says "sealmaster Stephens-adamson MFG ball bearing unit NP 12)
Can anyone out there tell me or confirm what this device is? please and thanks
ID:	340874   Click image for larger version
ID:	340875   Click image for larger version
ID:	340876   Click image for larger version
The Following User Says Thank You to CaptAndy For This Post:
Old 08-06-2019, 02:48:00 PM
Corn Corn is offline
Default Re: Pow'r Pup Power pup with Wisconsin AK
SealMaster was a bearing mfg based in Aurora IL.
Old 08-06-2019, 03:55:29 PM
pauljac pauljac is offline
Your photos are of a jackshaft with bear supports. The clutch appears to be the "pulley" on the engine crankshaft. Are there any markings on this pulley?
Old 08-06-2019, 05:59:12 PM
WD Garrett WD Garrett is offline
Link to original Power Pup plans.
https://www.vintageprojects.com/trac...ctor-plans.pdf
The Following 2 Users Say Thank You to WD Garrett For This Post:
Old 08-07-2019, 11:40:08 AM
Thanks for plans. I have those already. Mine is a little different.... their doesn't have these bearings/jackshaft. I understand their bearings just not sure why the pulley is going up to bearings and chain driving the same shaft as the pulley is already connected to... maybe to get it more torque??? just a guess.
A friend said maybe they were going to be running something else, like an implement, but they is no where to add anything. It just goes up connects to chain drive on back side and then comes back down to another pulley on shaft.
that pulley the chain is connected to doesn't have any marking but does look to have something inside ... new pictures are provided.
thanks team for help so far... and beyond.
ID:	340963   Click image for larger version
ID:	340964   Click image for larger version
Old 08-07-2019, 11:48:06 AM
The jackshaft allows installation of the centrifugal clutch on the crankshaft.
Old 08-07-2019, 12:10:53 PM
OK so that must be a centrifugal clutch down on the bottom that the chain is connecting to????
I have never seen anything setup like this... arguably at 34 years old I have not seen a lot! hah
Old 09-20-2019, 09:32:35 AM
Updated question - so my tractor doesn't have a clutch pedal. I was told one uses throttle lever to idle all the way down and then I shift from forward to neutral to reverse.
What is the name of this type of setup "throttle shifting garden tractor"?????
I am trying to find out more about this setup or videos of someone who throttles down and shifts and then throttles back up to get machine moving again.
Old 09-20-2019, 02:06:09 PM
Heins Heins is offline
The centrifugal clutch is mounted on the engine crankshaft as part of the V Belt.
Wisconsin TJD Power Gard 10KW Generator dukecharmary Wisconsin Engines 5 06-08-2017 11:34:54 AM
Lincoln SA200 Wisconsin VF4 power help GrumpyBobby Wisconsin Engines 18 07-11-2015 06:14:13 PM
Wisconsin VH4 Low power - help! Hugheski Wisconsin Engines 5 11-14-2014 11:10:16 PM
Wisconsin V4HD no power chadtil Wisconsin Engines 10 11-25-2011 03:16:27 PM
Wisconsin TH with US Light Power 5.5kw genset Shootist357 Generators & Electric Motors General Discussion 9 01-01-2006 04:48:28 AM
