Ford 2N stuck radiator drain cock
this thread has 9 replies and has been viewed 468 times
Old 08-21-2019, 11:49:10 AM
VicF VicF is offline
Default Ford 2N stuck radiator drain cock
Hi, I was going to change the antifreeze on my Ford 2N but I cant get the drain cock to turn. Iíve tried using some PB blaster but nothing works. Any Idea on what to do here? Thanks
Old 08-21-2019, 12:23:49 PM
Tracy T Tracy T is offline
Default Re: Ford 2N stuck radiator drain cock
remove lower hose? yeah i know its messy! some newer vehicles dont even have a drain anymore!
The Following User Says Thank You to Tracy T For This Post:
Old 08-21-2019, 12:27:23 PM
Probably what I’ll have to do. Not looking forward to it.
Old 08-21-2019, 06:35:50 PM
Are you trying to use the drain cock or take it out. I usually just pull the whole thing out when changing antifreeze.
Old 08-21-2019, 07:38:39 PM
Trying to use it. I just pulled the lower hose to get most of it out. Thanks
Old 08-22-2019, 12:05:01 AM
Ozlander Ozlander is offline
Are you turning it the right way?
It's either going to open or come out.
Old 08-22-2019, 08:28:15 AM
I have ran across ones that were so tight the bung came out of the tank! not too bad if you are good at solidering, but more work!
Old 08-22-2019, 09:48:06 AM
It won’t budge. I even tried using pliers. I don’t want to force it to much and snap it off.
Old 08-23-2019, 12:59:11 PM
Jack Innes's Avatar
Jack Innes Jack Innes is offline
If you stuff a long narrow rag through the hose opening to the bottom of the tank & let the other end hang lower than the tank bottom & over a container you will find over night it will syphon the remaining coolant out.
The Following 2 Users Say Thank You to Jack Innes For This Post:
Old 08-26-2019, 10:31:25 PM
Duey C Duey C is offline
I've snapped a couple off over the years so I know what you're asking Vic. And once we snap it off it's junk.
I was noodling in my head just now if we can get at it, can we lightly smack it with a brass shaft or some-such to try to loosen the threads and the seal a bit?
Like slip knot asked kind of. Can you remove the assembly? I don't know the Fords at all. Perhaps it's soldered in without a pipe thread nut to use a 7/16 or 1/2 inch wrench to pull the entire drain assembly.
Case L Radiator Drain Plug Airtractor76 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 05-30-2016 10:52:19 AM
looking for new cylinder drain cock valve bigredapes Steam Stationary Engines, Traction Engines 1 09-16-2014 12:08:23 PM
FairBanks Morse - Stuck Water Drain Plug Dale M. Hit & Miss Gas Engine Discussion 4 07-30-2014 12:57:19 PM
John Deere D Schebler Carburetor Drain Cock David Parfitt Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 02-10-2011 02:25:35 PM
Leaking drain cock - please help Chris AW Scale Model Engineering 15 08-07-2010 10:44:33 PM
