D Model John Deere Camshaft
this thread has 6 replies and has been viewed 637 times
Old 08-22-2019, 02:52:01 AM
john quigley john quigley is offline
Default D Model John Deere Camshaft
has any one have unwanted camshaft for above tractor ?
If so how much in Australian Dollars
Old 08-22-2019, 07:28:52 AM
Jack Innes's Avatar
Jack Innes Jack Innes is offline
Default Re: D model john deere
These people have one for $80 US. They seem very reasonable on their parts prices. https://vintagetractors.com/jddeng.html
The Following User Says Thank You to Jack Innes For This Post:
Old 08-27-2019, 06:30:50 AM
Inter Bloke Inter Bloke is offline
What year Model D are you looking at ?
I have a 28 model that I will be looking at getting the cylinders and piston/rod assembly's out of for a mate in several weeks, is it likely to have a compatible camshaft ?
I have no idea what condition the camshaft is in, but I can have a look at that time and see if its in serviceable condition !
I have moved from my previous residence (passed on the farm to my brother and his son) so don't get up there as often as I would like ( I am now 300 Ks away) but will look when I can if it will work in your situation !
Graham, now in Bunbury, not Quairading (must change that in my profile) !
Old 08-28-2019, 02:05:19 AM
Thank you very much camshafts run through many years unchanged should be compatible, If you could check condition and let me know I would be much appreciative
Regards John.
Old 08-31-2019, 06:07:00 AM
Default Re: D Model John Deere Camshaft
John,
I will have a look when I go up there in several weeks ! I have to give another mate a hand to get an old tractor going that he wants to take to the local show and its being a bit stroppy so will have an old tractor "fix" when I go up home.
How difficult would the cam be to get out, I don't have one to refer to down here but from memory it shouldn't take too long to extract would it ?
How soon do you need it ?
Graham
Old 08-31-2019, 07:45:41 AM
Jack Innes's Avatar
Model D camshaft removal & replacement;
Old 08-31-2019, 09:16:10 PM
Thanks Jack, that certainly makes the procedure clear !
Sounds straight forward, so as I will be playing around with the engine anyway it shouldn't be too hard.
Graham
1939 John Deere H camshaft Forrest A Antique Farm Tractors 1 04-10-2019 08:51:35 AM
John Deere 60 Camshaft Specs cub102 Antique Farm Tractors 0 10-28-2018 10:37:54 PM
H John Deere Camshaft removal Danny Antique Farm Tractors 4 10-31-2014 05:52:33 PM
John Deere 46 A Camshaft timing marks SlantdashA Antique Farm Tractors 4 01-19-2013 11:29:32 AM
John Deere BR with model 50 camshaft John Fischer Antique Farm Tractors 3 03-01-2010 11:37:03 PM
