Steam Engines
Steam Engine Ready to Fire
this thread has 13 replies and has been viewed 2806 times
Old 02-08-2011, 02:03:27 PM
lshadley lshadley is offline
Smile Steam Engine Ready to Fire
It has taken two months to free up this single cylinder engine, build a boiler and couple them together. Air tested to 100# and hydrostatic test to 200#. I'll move it out of the shop and have a first fire party this Saturday!
Name:	Steam Engine Completed 001.JPG
ID:	99855   Click image for larger version
Name:	Steam Engine Completed 003.JPG
The Following 4 Users Say Thank You to lshadley For This Post:
Old 02-08-2011, 02:15:53 PM
Dan Donaldson's Avatar
Dan Donaldson Dan Donaldson is offline
Default Re: Steam engine ready to fire
Interesting.
I have a few questions.
How is your boiler designed?
Plate grade & thickness, water tube or fire tube?
How to you add water?
Where is the pressure relief valve?
I do not see any stays on the flat surfaces.
Dan Donaldson
We never really grow up, we only learn how to act in public.
Old 02-08-2011, 02:20:27 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Appears to be some sort of water tube boiler?
Old 02-08-2011, 02:24:39 PM
I see the relief valve now. It is mounted on the steam line between the pressure gauge and the engine.
Dan Donaldson
To steal ideas from one person is plagiarism. To steal from many is research.
The Following User Says Thank You to Dan Donaldson For This Post:
Old 02-08-2011, 03:13:32 PM
Default Re: Steam Engine Ready to Fire
Here is a bit more info:
The engine was made before 1872 by the Sinker Davis Company in Indianapolis and we found it sitting in a back yard in Hayden, Idaho. Took a couple of days to get it freed up and running on compressed air. My son, Jim, supplied 3 pieces of 6” high pressure gas pipe for the mud pipes and steam pipe to construct the water tube boiler. The big pipes are connected by 10 short pieces of 1” schedule 80 pipe exposed to the fire to convert the water to live steam. I plan to run the boiler at about 75 psi
The certified blow-off valve does work as advertised at 150 psi and the sight glass accurately shows the water level in the boiler. I’ve got the governor backed all the way out so the engine runs at a nice slow 200 rpm. The feedwater pump is made from a hydraulic cylinder with check valves coupled to the upper part of the rod ( I think that was where the original was mounted ) and adjusting the stops on the slide rod control the amount of water injected on each stroke. I'll link to a video - much easier than trying to explain.
http://www.youtube.com/watch?v=cLkFh2Y-bmg
The Following 5 Users Say Thank You to lshadley For This Post:
Old 02-08-2011, 03:48:05 PM
AndyG's Avatar
AndyG AndyG is offline
Images: 7
Sounds like a pretty slick rig. Good luck and HAVE FUN!
Andy Glines
16 HP Huber # 8213
19 HP Keck-Gonnerman # 1789
"There's just something about steam!"
The Following User Says Thank You to AndyG For This Post:
Old 02-08-2011, 04:17:52 PM
Jim Mead Jim Mead is offline
Looking good...You might want to rethink the water glass placement. When things get hopping, it may or may not come under more stress than you think....that would also allow you to swing your pipe joints, something I try to do at least once in each pipe run between a boiler and any major appliance...
Just my 2 cents...
Jim
The Following User Says Thank You to Jim Mead For This Post:
Old 02-08-2011, 07:09:17 PM
Thanks. The lower pipe to the sight glass can pivot as needed and I threaded the bottom end of the guard rods and put on a captured nut just to make sure the compression joints on each end of the sight glass couldn't slip off.
Old 02-09-2011, 02:22:38 AM
Pete Deets Pete Deets is offline
Looking at the pictures a couple of times brings one question to mind. I didn't see any sort of lubricator, hydrostatic or mechanical, to feed into the steam line. Did I miss it?.....PD
The Following User Says Thank You to Pete Deets For This Post:
Old 02-09-2011, 07:17:09 AM
oldtractors's Avatar
Images: 5
The steam flowing past the site glass will probably distort the level when the engine is running, so the water level will read higher than it really is.
I think someone else already brought up the concern of the steam line vibrating from the engine movement, possibly causing the water glass to break.
Jim Evans
The Following 2 Users Say Thank You to oldtractors For This Post:
Model of American La France Steam Fire Engine Case Place Scale Model Engineering 261 03-08-2018 10:55:14 PM
1863 Amoskeag steam fire engine on ebay.. Davide L. Steam Stationary Engines, Traction Engines, Steam Boats 7 01-08-2012 02:21:59 PM
Steam Fire Engine Pic's - Natchez, Mississippi Mike Grivna Steam Stationary Engines, Traction Engines, Steam Boats 4 05-15-2011 11:56:33 AM
Getting Ready for the 50th Pageant of Steam Canandaigua New York Steve Harris Steam Stationary Engines, Traction Engines, Steam Boats 2 07-20-2010 06:43:47 PM
Trial of the Steam Fire Engine Report - 1876 Mark Antique Engine Archives 0 03-10-2000 12:43:03 PM
