How to: Convert ONAN CCK & MCCK 6.5KW to OEM Electronic Ignition
this thread has 52 replies and has been viewed 75030 times
Old 03-14-2017, 08:54:40 AM
electricaldoctor electricaldoctor is offline
Default Re: How to: Convert ONAN CCK & MCCK 6.5KW to OEM Electronic Ignition
I have a 1988 6.5 KW Onan MCCK generator in my boat. The coil is shot and I want to order some parts to get my genny operational for the 2017 boating season. In addition to replacing the coil, I would like to upgrade my existing points to electronic ignition. Can you point me in the right direction? That is a very good illustrated tutorial that you put together for us, but it does not work for me because I need a new coil. A new or used OEM coil will be a rare find, so can you recommend an alternative solution?
~Ken
Old 03-14-2017, 04:21:48 PM
preskitaz preskitaz is offline
I just upgraded my 7.5JB to electronic ignition and Propane using the points but it triggers a GM HEI module ($25) to fire the coil. The same can be done on your setup. The points trigger the module but since its low current they wont wear like the do with conventional points circuit (practically forever). I'll post some pictures of what I did because the coil on the JB is 6v not 12v. Its cheap and the best part is not having to figure out where to stick magnets on the flywheel and muck with the timing in the process. As for the coil I believe there are still coils available I read in a thread somewhere, try a search.
The Following User Says Thank You to preskitaz For This Post:
  #43
Old 03-15-2017, 11:07:58 PM
I know it's not a cck but I have a JB 7.5 I successfully converted. The same circuit can be used on any onan that uses 12v and points.
Name:	2017-03-15 18.57.13.jpg
ID:	277603   Click image for larger version
ID:	277604   Click image for larger version
The Following 2 Users Say Thank You to preskitaz For This Post:
  #44
Old 03-16-2017, 12:55:27 PM
Don't know how to go back and edit my post but I got a label wrong on one of the wires. Anyways this is the correct image. I mounted the HEI module to an old Pentium heat sink I had laying around. Amazon has the specific heat sink for the module. In the one picture my points are located above the oil filter. I removed the condenser and ran the wire into the control box where the new ignition circuit is located. I left the ballast resistor on the coil and since the HEI module uses 12 volts, I connected the power to the front side of the resistor (not after ). The transistor and R1 I mounted on a small breadboard and used sealing heatshrink to cover it. Using this circuit I was able to make it more reliable since the new points won't wear because of the low current switching. I'm also able to still adjust the timing by adjusting the points as stated in the manual.
  #45
Old 03-16-2017, 06:34:34 PM
deno deno is offline
Parts list? I have a 4.0 BGE on an '89
The Following User Says Thank You to deno For This Post:
  #46
Old 03-17-2017, 07:32:44 AM
Standard Motor Products LX301T Ignition Module/Control Unit - Amazon.Com $18.96
Heatsink for module
4.7k ohm resistor 1/4 watt resistor
2N2222 or equiv. NPN transistor, min gain 150
That's pretty much it
The diagram I used is attached
Old 03-17-2017, 07:34:43 AM
Make sure you remove the condenser from the points when you install the circuit in fig 1 on my picture
Old 04-01-2017, 07:15:08 AM
Waste spark coils are what you need.
2 cylinder motorcycles and the Saturn 4 cylinder mid 90's engine use them as well as many others.
I have a thread where I did this idea for two MCCK engines. I tried one circuit but did not work, then found another which did, something to do with older 4 pin GM modules, they do not all work the same.
Old 05-02-2017, 01:58:12 PM
len k len k is offline
My thread summarizing some car and other ignition moduals
https://www.smokstak.com/forum/showthread.php?t=167037
Old 05-16-2017, 07:33:44 PM
dracer dracer is offline
Heatsink for module
thank you , for the info , used it for a 4.o that I picked up that had a bad condenser , it did not cost that much more than a new condenser would have (I bought a cheap module ) since I had to buy 10 transistors and 30 resistors I some left to convert others thanks again Roger
Trying to convert to Electronic ignition w/Magna Arc jwrape Onan Generators 61 08-06-2008 01:25:58 PM
electronic ignition Alan R Small Air Cooled Gasoline Engines 5 05-03-2007 08:49:23 PM
Electronic Ignition Gunny Onan Generators 22 01-31-2007 07:21:48 AM
Electronic ignition for Onan BF-MS 3271E lwhiway Small Air Cooled Gasoline Engines 0 09-13-2006 04:01:49 PM
Need a electronic ignition for IH Tractor Kevin M. Antique Engine Archives 1 03-20-2003 03:31:21 PM
