Need a electronic ignition for IH Tractor
this thread has 1 replies and has been viewed 2708 times
Old 03-20-2003, 09:21:08 AM
Kevin M.
Default Need a electronic ignition for IH Tractor
Looking for an electronic ignition for an IH Tractor (British made - Lucas Electrics). I recall several mfrs however cannot remember their name. Thoughts and experience appreciated.
Old 03-20-2003, 03:31:21 PM
Bob (ND)
Default Re: Need a electronic ignition for IH Tractor
Pertronics (formerly Per-Lux) makes simple electronic ignition conversions for a variety of applications, but I don't know if they have one for the Lucas. A search on Google will get you a bunch of sources for Pertronics.
If they don't have one for your application, it is possible to take a basic Pertronics unit for a Chevy or Ford distributor and re-work it to fit in your distributor. If you need to go this route, by sure to mount the unit so the rotor is properly "phased", i. e., that when the module produces a spark the tip of the rotor is near the desired high tension output terminal in the distributor cap.
http://www.google.com/
CCK Electronic Ignition Project. VaughnSimon Onan Generators 19 09-30-2007 04:55:16 PM
electronic ignition Alan R Small Air Cooled Gasoline Engines 5 05-03-2007 08:49:23 PM
Electronic Ignition Gunny Onan Generators 22 01-31-2007 07:21:48 AM
electronic buzz coil or ignition? grant31781 Magnetos, Ignition Coils and Spark Plugs 17 01-21-2006 07:50:53 PM
Adding electronic ignition to 4.0 CCK GADavis Onan Generators 1 12-01-2005 09:59:35 PM
