1978 Onan 6.5NH Tune Up
this thread has 3 replies and has been viewed 396 times
Old 01-22-2018, 12:12:52 AM
billyrb billyrb is offline
Default 1978 Onan 6.5NH Tune Up
I have a 1978 Wanderlodge with an onan 6.5NH-3CR/12894D. I want to give it a tune up, wondering if anyone knows the part numbers for air filter, spark plug wire, oil filter, etc?
Old 01-22-2018, 12:48:00 AM
lokay5's Avatar
lokay5 lokay5 is offline
Default Re: 1978 Onan 6.5NH Tune Up
Before you do anything to your NH - check the condition of the ignition points and the ignition condenser. If they're bad, nothing you do will make a difference.
I suggest you start there, but others will certainly disagree.
1973 CK5 Blazer
Old 01-22-2018, 07:18:23 AM
Kevin K Kevin K is offline
Stop by the Twinslan site: http://www.twinslan.net/~n0nas/manuals/onan/
Download the manuals for your spec D 6.5NH
940-0501 service
940-0221 parts
940-0223 parts
940-0121 operator
900-0186 wiring diagrams
Your wiring diagram is 611-1142 on page 63 of the wiring diagrams manual.
The Following 2 Users Say Thank You to Kevin K For This Post:
Old 01-22-2018, 11:34:09 AM
armandh armandh is offline
Onan parts https://onanparts.com/index.php?main_page
provided points plugs and condenser for a 6.5-KW NH.
auto parts store for the oil filter.
and, if needed, shop carefully for a LOW PRESSURE fuel pump
a 1978 motor home pull-out is now my daughter's house hold back-up
it had not run in 10 years, points and pump were way bad. now runs great.
by using this free advise, you, your heirs, etc
absolve, save, and hold harmless the advisor.
CAVEAT EMPTOR
YMMV
Onan Generator : 1978 for Kings Highway RV. Fuel Pump electrical issues? Cmchapman75 Onan Generators 22 12-06-2016 03:25:01 PM
Onan 6.5 nhd final tune need some help Texwing Onan Generators 12 07-15-2015 01:06:37 PM
Onan RJC tune up parts Daverepair Onan Generators 4 03-01-2013 04:44:47 PM
Onan MDJA Wiring Diagram (4/25/1978 version) RossJo Onan Generators 3 12-23-2011 09:35:31 AM
1978 Ford Skid-Steer with Onan NHC engine will not start! Merc300SD Onan Generators 7 03-26-2011 11:18:03 AM
