Magneto Question
this thread has 12 replies and has been viewed 1387 times
Old 03-01-2018, 07:30:12 AM
Default Magneto Question
Way back when, we discussed tractor magnetos and grounding out spark plug wires that were not being used, such as when using a 4-cylinder mag on a 2-cylinder engine.
A friend is working on a mag for another friend right now. It is a 4-cylinder Robert Bosch for a Hart Parr. Bosch has looked after the unused leads. He says there is an "air gap" where you can see the spark being made.
His question is, is it better to allow the unused wires to make a spark somewhere, or does it do just the same thing to simply take them direct to ground.
Do they need to make an actual spark for the betterment of the coil, etc.?
Thank you for any thoughts.
Old 03-01-2018, 08:25:17 AM
Kelly Tytlandsvik Kelly Tytlandsvik is online now
Images: 407
Default Re: Magneto Question
Hi G
My understanding is the wider the gap the more the coil has to put out and greater the chance of it shorting out the coil. So by having a gap something along the lines of what the spark plug would have would make the coil put out the same as when it is connected to a plug. If the unused terminals are left open or ungrounded then the coil will be forced to put out higher voltage and risk ruining the coil. If the terminals are grounded the current will have a place to go and the coil will put out less voltage therefore saving the coil.
I think with the magneto you are talking about must have been a flavour of the day??????? Not sure but grounded or gapped would still keep from damaging the coil.
I think I just babbled and wasn't much help????
Kelly T
The Following User Says Thank You to Kelly Tytlandsvik For This Post:
Old 03-01-2018, 08:40:21 AM
G W,
Kelly is correct. The "spark that you see being made" is a safety gap in case a wire happens to get disconnected. It was never intended to operate continuously. The voltage required to jump the safety gap is significantly higher than that required to jump the spark plug, otherwise it would cause misfires. Forcing the safety gap to conduct puts a lot of voltage stress on the coil. The fact that it's now a nearly 100-year-old coil is not in your favor.
Kirk
The Following User Says Thank You to Kirk Taylor For This Post:
Old 03-01-2018, 10:36:42 AM
9 hp Alamo 9 hp Alamo is offline
My father has a 18-36 Hart Parr that has a four cylinder Fairbanks mag on it, and those wires are directly grounded; bolted to the mounting bracket. As far as we can tell that mag has been on there for a good 50+ years and we've never has any trouble with it, or heard of the previous owner having trouble.
-Good luck
The Following 2 Users Say Thank You to 9 hp Alamo For This Post:
Old 03-01-2018, 01:26:31 PM
Exclamation Re: Magneto Question
The un-used ignition terminals should be grounded in order to reduce excess stress on the coil. As others have noted, to use the safety gap built in, is not a good idea. Also - do not use resister (modern carbon core) wire on a magneto. Too much rsistance will damage the coil.
The Following 2 Users Say Thank You to Andrew Mackey For This Post:
Old 03-01-2018, 02:48:12 PM
Ken Majeski's Avatar
Images: 46
How about the Bosch DU 4/2 mags used on the lightweight Rumelys ? Seems like they have this Little Gizmo connected to 2 terminals.
Frankly I think it makes little difference if you ground the unused wires or use a spark gap as long as it's not too wide. But something about a Extra unshielded spark around an engine that is already loaded with Hot oil and Gas Fumes don't exactly give me a Warm Fuzzy Feeling
Ken Majeski, Ellsworth Wis.
The Following 2 Users Say Thank You to Ken Majeski For This Post:
Old 03-01-2018, 09:01:32 PM
halcon halcon is offline
Those gizmos are flame arresters-----fear not.
Old 03-01-2018, 09:31:38 PM
Jon Nessel's Avatar
Jon Nessel Jon Nessel is offline
Going from memory, the DU4/2's safety gap is adjustable.
Old 03-01-2018, 10:50:44 PM
Most high tension magnetos have a safety gap which is under the porcelain insulator in Bosch Du-4 and KW and others. The IHC E4 & F4 Have it inside. The Bosch DU4-2 has a little one on the outside of the distributor cap for the two unused outputs. The gap is usually protected with a fine screen. When grounded (shorted) or with a safety gap, the voltage induced in the secondary is all or mostly dropped by the coil's internal impedance and is not developed. If allowed to operate at open circuit, the full voltage will be developed and may jump between turns of wire in the secondary eventually destroying it. There are 10,000 to 20.000 turns of wire. The dielectric strength of the secondary insulation on the wire and between the turns of wire protect it. However magnetos with a varnish which contains solvents as in years past will have voids where the solvent evaporated from and will not be protected as well as those with vacuum impregnated insulation varnish without solvents to evaporate. The dielectric strength is very important in high voltage applications.
The Following 3 Users Say Thank You to Oilpulled For This Post:
Old 03-01-2018, 10:54:24 PM
Images: 46
Yup Clyde, Plus the fact that the wasted sparks are inside the Die cast Mag Cover if it hasn't disintegrated and Fell Off.
The Following User Says Thank You to Ken Majeski For This Post:
IHC L magneto question. Barry Chorum Antique Gas Engine Discussion 2 08-22-2014 08:48:47 PM
Magneto Question 1937witte Magnetos, Ignition Coils and Spark Plugs 1 11-11-2010 04:49:01 PM
IHC M Magneto Question Tom Martin Antique Gas Engine Discussion 10 02-21-2007 09:19:16 AM
Magneto Question Rich Martz Antique Engine Archives 2 05-26-2004 01:02:19 AM
Magneto Question Tom Wahl Antique Engine Archives 2 06-05-2002 12:39:54 AM
