Delco 850 1918
this thread has 9 replies and has been viewed 1087 times
Old 09-23-2017, 07:05:55 PM
pweigold pweigold is offline
Default Delco 850 1918
I bought a very nice early 850 with what amp hour meter on eBay very good condition but took the brush cover off and found the age old mouse nest and pulled the field coil asm off . looking and cleaning I saw the corner of a peace of paper in the engine cooling channel I posted the what I found if I did it right that is
The Following 2 Users Say Thank You to pweigold For This Post:
Old 09-23-2017, 07:34:37 PM
netpirate8 netpirate8 is offline
Default Re: Delco 850 1918
That is a sweet find!!
Old 09-24-2017, 04:24:26 PM
cammer cammer is offline
it seems like 1918-1919 are everywhere i have two my self youtube restored delco light plant Jon in KY
Old 09-24-2017, 06:42:49 PM
Got the light plant on Thursday and heard it fire a few times on 24 volts time to get battery's you can see your self in the1918 paint lead you got to love it attached a couple of pics of the amp hour meter unrestored as found
ID:	292116   Click image for larger version
Old 09-24-2017, 08:42:14 PM
Tim B's Avatar
Tim B Tim B is offline
Very very nice. Did you notice it working? I have one my Phelps and a few people commented not many work today. What batteries are you planning on running? I use 3 Walmart garden tractor batteries 19.95 each for display purposes. Of course I take them out of my lawn tractors for the show. Keep us in formed and a video please. Thanks and good luck
Old 09-25-2017, 04:19:26 PM
Yes used 3 small garden tractor battery's and started no problem meter is turning charging starts stops very happy with it I have a small 32 v - 115 AC motor generator converter 150 w working on it as well
Old 09-27-2017, 11:01:17 AM
You know, you should clean that paper off very carefully with a soft brush and make copies....on light card stock if you can. I'm sure there's more than one Delco owner out there that would like to have such a reproduction!
Old 09-28-2017, 09:13:40 AM
I could and should do that I have a friend that's a printer
Old 09-30-2017, 07:44:26 AM
There are also computer programs that can "clean up" the original image so that it looks new again. Why not check into it and get back to us with an estimate? It would make a nice, visible accessory for the shows!
Old 10-02-2017, 06:28:54 PM
OK will look into it
1918 Delco Movie Bill Hazzard Delco and other Low Voltage DC Light Plants 8 01-27-2018 01:56:54 AM
Delco-Remy/AC-Delco Dist/Gen/Starter Etc Numbers Bud Tierney Antique Autos and Trucks 0 01-05-2015 05:09:03 PM
1918 Delco light plant BookEm Delco and other Low Voltage DC Light Plants 1 11-17-2011 02:05:25 AM
1918 IHC 1 1/2hp M turnwaldw YouTube Old Iron Videos 4 10-15-2009 01:43:28 PM
1918 3 horse IHC M Joe Musser Antique Gas Engine Discussion 7 06-26-2006 05:05:49 AM
