Delco Light Plant - need help
this thread has 11 replies and has been viewed 1597 times
Old 01-27-2018, 07:11:38 AM
Elden DuRand's Avatar
Images: 11
Default Re: Delco Light Plant - need help
"I have a 32 volt radio that I won't run on 36. I intend to build a 32 volt regulator in it for protection."
Steve:
Anything below about 39 volts won't hurt the radio because it was designed to be operated off of a fully charged (or charging) 32 volt battery bank is approximately fully charged when they are at about 37.5 volts.
Remember that 6 volt tube type car radios did fine at a little over 7 volts and the 12 volt ones were fine at around 14 volts.
Take care - Elden
http://www.eldensengines.com
Old 07-29-2018, 10:07:03 PM
FDChief FDChief is offline
The very early overhead valve Delco‘s were all cast-iron heads and cylinders. The copper cooling fins came about in the 30s with the automatic start plants. The last ones to be built used an L head design and they went back to cast-iron possibly with an aluminum head.
Delco Light Plant 752 Phil King Delco and other Low Voltage DC Light Plants 6 05-31-2015 07:18:01 AM
New here -- Delco light plant Bob Early Delco and other Low Voltage DC Light Plants 5 11-17-2005 08:55:54 PM
Delco Light Plant Jordan Delco and other Low Voltage DC Light Plants 4 11-06-2005 07:31:43 PM
delco light plant George Gersmehl Delco and other Low Voltage DC Light Plants 2 05-21-2001 07:29:09 PM
