Economy 1 1/2hp type e
this thread has 13 replies and has been viewed 581 times
Old 03-15-2019, 12:18:02 PM
vicf vicf is offline
Photo Economy 1 1/2hp type e
Hi, Here are some pics of my first hit and miss engine that i bought yesterday. Big thanks to Galan Hackman for selling me this engine and helping my dad backdown his driveway. I'll record a video of it running this afternoon. I'm currently planning on replacing the cylinder head as there is an old repair that causes it to smoke.
ID:	330668   Click image for larger version
The Following 6 Users Say Thank You to vicf For This Post:
Old 03-15-2019, 03:30:38 PM
Keith Kinney's Avatar
Keith Kinney Keith Kinney is offline
Default Re: Economy 1 1/2hp type e
Very nice! Send me your email address and I'll send you a copy of the owners manual.
Keith Kinney
www.HerculesEngines.com
The Following 3 Users Say Thank You to Keith Kinney For This Post:
Old 03-15-2019, 06:54:58 PM
vicfiori252@gmail.com
---------- Post added at 06:54:58 PM ---------- Previous post was at 06:53:53 PM ----------
https://youtu.be/vK6CoOSJMyA
Old 03-15-2019, 07:21:19 PM
Joel Mosley's Avatar
Joel Mosley Joel Mosley is offline
Images: 27
Nice looking and nice running economy engine. What is wrong with the head?
Old 03-15-2019, 11:08:34 PM
I was told that the exhaust valve hole was repaired with either epoxy or jb weld. So the valve doesn't seat right.
Old 03-16-2019, 01:37:07 PM
26kracing 26kracing is offline
If it runs the valve is seating ok and you mentioned about it smoking the head will not cause this itís either to rich or your dripping to much oil nice engine and welcome to the addiction
Old 03-16-2019, 04:43:01 PM
Oil - 6 to 10 drips/minute using SAE 30 oil. NO multigrade! The piston should look wet with oil as the engine is running. if it looks dry, add more oil/minute until it looks wet Over oiling wont hurt but will waste oil and possibly could cause white smoke and ignitor or spark plug fouling. Black smoke means the engine mixture is too rich. Close mixture scres by 1/8 turns and let engine runa few mintes to cler out the excess fuel. Adjust until the engine begins to double draw and back out until the engine hits at the first suction. Epoxy is a poor fix for heads, but if you do not load the engine,and you are not loosing compression out the exhaust, if it works, don't fix it! If youare blowing out the exhaust on the compression steoke, then you might have to see if a new seat can be installed. a competant machine shop should be able to fix it for less than a coet of a head.
Old 03-16-2019, 04:49:39 PM
Default Economy 1 1/2 type E issues
Hi, so i just got this engine and I have ran into some problems. So I had the engine running find until recently it wonít continue you running. It will start run for maybe 15 seconds or so and then stop. I have noticed that the compression isnít has good as it once was. I also noticed a like popping noise coming from the back of the cylinder. I know there was an issue with the cylinder head having an old repair that caused the valve to not seal all the way. Thanks
Old 03-16-2019, 04:51:16 PM
Dennis Peters Dennis Peters is offline
Nice engine, nothing wrong with the way that one runs. I don't think I'd touch the head. Also welcome to the STAK
The Following User Says Thank You to Dennis Peters For This Post:
Old 03-16-2019, 06:20:57 PM
Default Re: Economy 1 1/2 type E issues
UPDATE: So I decided to remove the cylinder head to inspect and found a lot of carbon build up. I reattached the head and tried starting it. It would start but only hit once or twice. I found that it draws fuel up but then starves itself. When I increase the fuel it either floods itself before even starting or firing and then flooding. Something interesting that I noticed is that I had a similar issues yesterday but I eventually got it running. Earlier in the day today I had it running, When i moved it to a flatter location it ran for 2 minutes before dying.
Anyone know what type of engine this is? (Economy) FibberMcgee Antique Gas Engine Discussion 10 05-13-2018 02:36:02 AM
Economy Engine - What type of fuel? MOOS Antique Gas Engine Discussion 4 10-23-2016 09:44:48 PM
Economy id / type of ignition Eric McKenna Antique Gas Engine Discussion 7 09-25-2013 01:16:21 PM
What Type of Carb? Tag Reads Economy Type F (Log Saw) Ray T Antique Gas Engine Discussion 11 11-17-2009 08:48:16 PM
New Economy type G Brickman Antique Gas Engine Discussion 2 01-07-2008 12:58:28 AM
