Huber 40-62?
this thread has 63 replies and has been viewed 12507 times
Old 08-06-2016, 11:40:04 PM
d21smith d21smith is offline
Default Re: Huber 40-62?
ID:	2597902 more views
The Following 5 Users Say Thank You to d21smith For This Post:
Old 10-19-2018, 09:50:18 AM
bmkeste bmkeste is offline
I recently acquired two Hubers:
1938 40-62 Serial Number 13335
1925 15-30 Serial Number 7770
Any historical information on either of those tractors would be greatly appreciated!!
Thank you
The Following User Says Thank You to bmkeste For This Post:
  #43
Old 10-19-2018, 11:19:23 AM
Number 7770 is shown as being sold to William Mack at Spencerville, Ohio on 9/28/1925.
Number 13335 is too new for the list I have.
  #44
Old 10-19-2018, 02:11:39 PM
I need all 4 steel wheels for a 40-62 Huber. 25-50 will do. PM if you have them.
Old 10-20-2018, 10:06:34 AM
Mark Schleppi Mark Schleppi is offline
#13335 is a 40-62 built with steel wheels & low speed gears coupled with 3” cleats. Built 6/28/38.
Happy Hubering
MSS
Old 12-15-2018, 05:16:50 PM
Titan1020 Titan1020 is offline
We just hauled home a Huber that's been sitting outside for years and has lost its serial tag. The engine is a Waukesha DKR 3 D, 4-3/4x6-1/4, #237306, dated April 1930. It's on rear steel, front cutoffs. It has some potential so we are curious what it is. We are thinking 18-36 hoping one of you Huber experts could assist with identification. Thanks in advance!
The Following User Says Thank You to Titan1020 For This Post:
  #47
Old 12-18-2018, 04:46:18 PM
Titan:
The DK Waukesha was used in the 20-36. The 18-36 is a tractor with a larger chassis and a Stearns power plant.
Happy Hubering,
MSS
The Following User Says Thank You to Mark Schleppi For This Post:
  #48
Old 12-18-2018, 09:20:40 PM
Originally Posted by Mark Schleppi View Post
Titan:
Happy Hubering,
MSS
Thanks very much for the information! Much appreciated!!
Old 01-17-2019, 08:11:25 PM
Joe ONeill Joe ONeill is offline
Can anyone tell me the firing order for a 40-62 stearn engine?
Old 01-17-2019, 08:44:34 PM
There are 2 firing orders for 4 cylinder engines. They are 1 - 3 - 4 - 2 or 1 -2 -4 - 3.. Take all the plugs out, crank it over and when you find TDC #1. Place a chalk mark on the front pulley. When you turn the engine close to 1/2 turn and with your thumb over the spark plug hole see if #2 or #3 is coming up on compression. Once you determine which cylinder is coming up on compression check where the position of the rotor is and install the wire in the cap. When you turn the engine another half turn to where your chalk mark lines up again the rotor should be lined up with #4. Questions, send me an e-mail and include your phone number. Good luck.
Old 01-18-2019, 09:54:22 AM
Baker Maker Baker Maker is offline
Images: 11
sn# 10512 built 4-23-30 sold 7-10-30 to Granville Horn of Mentoue? Ind. model 20-36
Old 01-18-2019, 11:48:26 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Baker Maker, where did that # come from, what tractor are you referencing?
Old 01-18-2019, 03:39:00 PM
Thank you John. Would send e-mail if I had your e-mail address.
Mine is jcadillac@live.ca
The tractor belongs to the Canadian Transportation Museum and Heritage Village at Essex Ontario Canada which I volunteer to help restore vehicles, equipment and buildings.
Old 01-18-2019, 07:33:07 PM
Images: 11
sn# is for titan 1020 post #46 Sorry Frank.
Old 01-18-2019, 08:01:30 PM
FWurth's Avatar
One Millionth Post
Images: 4
The reason I ask, were you able to cross reference from the motor SN? As he didn't have a tractor # . Just curious. Thanks
Old 01-19-2019, 11:13:11 AM
Images: 11
engine sn# is listed in the build book if the same engine thanks frank.
The Following User Says Thank You to Baker Maker For This Post:
  #57
Old 01-19-2019, 12:26:01 PM
Fantastic! Thanks again for that information. My brother will be very happy to get that. Tractor was sitting in northwest Ohio for years so it wasn't too far away from Indiana.
  #58
Old 03-12-2019, 10:40:38 PM
Does anyone know of a 40-62 operator's manual available anywhere? Original would be preferred of course, but a copy would be just fine as well. Thanks!
---------- Post added at 09:40:38 PM ---------- Previous post was at 09:27:44 PM ----------
Sorry for the double post, but I also meant to ask about changing oil in my 40-62. Does anyone know if there is an oil filter and gasket made that would fit my 1938 Huber 40-62?
Also, does anyone have an opinion on what type of oil to use? I've read 30W...I've read 15W-40 diesel oil....etc. Anyone have a solid opinion?
Thanks!
  #59
Old 03-13-2019, 01:09:21 AM
FWurth's Avatar
One Millionth Post
Images: 4
Either oil will do well, I use straight 30 wt. in mine as it's on hand at the farm in bulk. These present day oils we have now are vastly better than what was available when these tractors were new. The thing I did with mine was to drop the crankcase cover and clean out the sump as it had a lot of sludge in the bottom, now the oil stays nice and clear. I got a reprint manual from the Engineers and Engines people some years back. It has some specs and very general operating instructions in it, but not much else. My oil filter has the washable sock element in it, so we use it. Some times you can save the ends from an old filter and use them to sandwich a modern cartridge element between the ends and with a bit of spring pressure from the top, it works fine.
  #60
Old 03-13-2019, 02:01:24 PM
Thank you for the info! Do you use straight 30 “non detergent”. My fear in using detergent oil is it might break up old sludge and hurt the engine. Thoughts?
Huber 20-36 John Rhodes Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 07-08-2013 09:08:11 AM
New Huber? Fraudulent Sale on Ebay 30 hp Huber Colin Farquhar Steam Stationary Engines, Traction Engines 34 08-30-2011 05:58:18 PM
New Huber? Colin Farquhar eBay© Auction Discussion 15 08-27-2011 12:18:08 PM
Huber Steam engine & Huber Tractor to be Auction Nov 7th roebersauctions Live Auctions of Engines, Tractors and Old Iron 16 11-10-2009 10:40:19 PM
NEW HUBER andy glines Steam Stationary Engines, Traction Engines 1 12-05-2003 03:13:12 PM
