Huber 40-62?
this thread has 63 replies and has been viewed 12507 times
Old 03-13-2019, 02:11:22 PM
Russ Hamm's Avatar
Russ Hamm Russ Hamm is online now
Images: 1
Default Re: Huber 40-62?
Originally Posted by bmkeste View Post
Thank you for the info! Do you use straight 30 “non detergent”. My fear in using detergent oil is it might break up old sludge and hurt the engine. Thoughts?
I would sure stick with non detergent. I usually take an engine completely apart and clean it but last year I bought an FTA that was already running so when I changed oil I put in 30wt. detergent and basically gave it a detergent oil enema. Oil was seeping out the exhaust gaskets down the side of the heads, sucked in the oil filter and it took two more oil changes with non detergent to somewhat straighten things out. Yoowsaah!
Old 03-13-2019, 03:16:44 PM
casertractor casertractor is online now
Originally Posted by Joe ONeill View Post
Thank you John. Would send e-mail if I had your e-mail address.
Mine is jcadillac@live.ca
The tractor belongs to the Canadian Transportation Museum and Heritage Village at Essex Ontario Canada which I volunteer to help restore vehicles, equipment and buildings.
https://www.smokstak.com/forum/showt...tractor+serial
Old 03-13-2019, 05:01:37 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
That's why I clean out the oil sump and every place I can before we run them. Most old engines can be accessed by dropping the pan and side covers and the valve cover, a good scrubbing and rinse will get most every thing cleaned up.
  #64
Old 03-13-2019, 10:48:35 PM
Bob Willman Bob Willman is offline
Does anyone know of a 40-62 operator's manual available anywhere? Original would be preferred of course, but a copy would be just fine as well. Thanks!
---------- Post added at 09:40:38 PM ---------- Previous post was at 09:27:44 PM ----------
Sorry for the double post, but I also meant to ask about changing oil in my 40-62. Does anyone know if there is an oil filter and gasket made that would fit my 1938 Huber 40-62?
Also, does anyone have an opinion on what type of oil to use? I've read 30W...I've read 15W-40 diesel oil....etc. Anyone have a solid opinion?
Thanks!
I have an original Huber manual that covers the Huber "HS", "HK", "HK" Special and the Super Four Model 40-62 H.P. It is not dated and is printed by The Gray Printing Co. in Fostoria, Ohio. It is 11 pages not including the front and rear covers. It is in almost new condition. It has 26 photos of the different tractors, specific parts, engines and transmisions.
Bob
WB8NQW
The Following User Says Thank You to Bob Willman For This Post:
Huber 20-36 John Rhodes Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 07-08-2013 09:08:11 AM
New Huber? Fraudulent Sale on Ebay 30 hp Huber Colin Farquhar Steam Stationary Engines, Traction Engines 34 08-30-2011 05:58:18 PM
New Huber? Colin Farquhar eBay© Auction Discussion 15 08-27-2011 12:18:08 PM
Huber Steam engine & Huber Tractor to be Auction Nov 7th roebersauctions Live Auctions of Engines, Tractors and Old Iron 16 11-10-2009 10:40:19 PM
NEW HUBER andy glines Steam Stationary Engines, Traction Engines 1 12-05-2003 03:13:12 PM
