Avery Tractor Identification
this thread has 58 replies and has been viewed 13454 times
Old 11-18-2014, 01:34:47 PM
2030rumely 2030rumely is offline
Default Avery Tractor Identification
Hello Members,
I have recently found the remains of an old Avery tractor and am try to find out the year and model.
I can not figure out how to post a photo. If there is an Avery guru out there I would be glad to email him or her some photos for identification.
Thanks for any response.
---------- Post added at 11:34 AM ---------- Previous post was at 10:38 AM ----------
I just received a notice from one of the members but my browser blocked it. You can reach me at garybo@embarqmail.com
The Following 5 Users Say Thank You to 2030rumely For This Post:
Old 11-18-2014, 08:15:26 PM
Jason W Jason W is offline
Default Re: Avery Tractor Identification
Helping Gary out.
ID:	211138   Click image for larger version
ID:	211139   Click image for larger version
ID:	211140   Click image for larger version
Old 11-18-2014, 08:17:40 PM
Second group
ID:	211142   Click image for larger version
Name:	Pic 6 avery.jpg
ID:	211143   Click image for larger version
ID:	211144   Click image for larger version
The Following 12 Users Say Thank You to Jason W For This Post:
Old 11-18-2014, 08:19:41 PM
last group
ID:	211146   Click image for larger version
The Following 11 Users Say Thank You to Jason W For This Post:
Old 11-18-2014, 08:26:28 PM
Thank you Jason for posting the photos of the Avery.
The Following User Says Thank You to 2030rumely For This Post:
Old 11-18-2014, 08:33:31 PM
Ed Dina's Avatar
Ed Dina Ed Dina is offline
Avery Model 20-35 Very rare...Look on the top of the front frame cross member..Should be a serial number stamped in...Same frame size as the 25-50. Same bore and stroke as a 40-80 only two cylinders...made from 1912-1915. Serial number should be under that extra set of wheels, on the right side on top
The Following 5 Users Say Thank You to Ed Dina For This Post:
Old 11-18-2014, 08:37:48 PM
Tim Colwell's Avatar
Tim Colwell Tim Colwell is offline
Good find! Will we be seeing a restoration thread this winter!?
Tim
The Following User Says Thank You to Tim Colwell For This Post:
Old 11-18-2014, 11:02:54 PM
What a find.......
Right away I knew it's an early one with no notches in the flywheel.
A 12-25 I owned had a single notch in the flywheel for a starting bar.
Old 11-19-2014, 01:26:00 AM
sprint8f sprint8f is offline
Sometimes the flywheel is stamped as well with the tractor #. Engine # can be there as well or on the end of the crankshaft. 20-35 engine numbers started with H prefix. Very nice find.
Matt
The Following User Says Thank You to sprint8f For This Post:
Old 11-19-2014, 02:18:56 AM
Wow, what a find! Hope you can get it!
Mike M
The Following User Says Thank You to Mike McKnight For This Post:
Old 11-19-2014, 05:00:22 AM
Alastair Geddes. Alastair Geddes. is offline
Looks like a good project tractor no matter what the final model turns out to be.
I forsee lots of work ahead.........
The Following User Says Thank You to Alastair Geddes. For This Post:
Old 11-19-2014, 11:43:31 AM
Thanks everyone for all the information in identifying and wishing me luck in obtaining the tractor. I'll let you know how it turns out.
The Following 3 Users Say Thank You to 2030rumely For This Post:
Old 11-19-2014, 01:53:10 PM
Jim Harbauer Jim Harbauer is offline
What a great find. I am really glad to finally see some guys finding nice tractors in the weeds and not having to sell the farm to get them .Its amazing what has been found just in the last couple months .Makes you wonder whats out there yet .Good luck getting it bought and home in the barn .If you need a carb for it, I have a 10 ball Kingston thats too small for my 25-50. I think its for an 18-36 or 20-35. Not sure. Jim
The Following 2 Users Say Thank You to Jim Harbauer For This Post:
Old 11-19-2014, 01:56:37 PM
Thank you Jim I hope I will be calling you.
Old 11-19-2014, 02:59:40 PM
handyman1 handyman1 is offline
Hi Gary;
Great pictures. That tractor just says "CHARACTER" all over it.
Thanks,
Alan
Old 11-19-2014, 04:36:37 PM
Man, I must be seeing the wrong picture. When I looked at it mine said "Expensive but worthwhile project!" LOL!
It really is a nice find for the rarity. I wonder what the radiator will take to fab?
Old 11-23-2014, 10:46:44 AM
Hello Members,
I am happy to say we are the proud owners of the Avery tractor. After spending two days preparing the tractor for movment we have found we still know little about this tractor. We just discovered the engine slides back and forth on a rail. We could not find a serial number on the top front of the frame but we did find some numbers in other places. On the inside of the engine slide rail under the radiator position we found 306 stamped in the rail. On top of the engine block and on the end of the crankshaft we found 5217. Almost all numbered parts began with 35. We found R 13 stamped on the face of the cylinder block that would be covered with the head gasket. We found H2 stamped on one of the cylinder heads. We found 459 stamped on the hub of the flywheel. We found H 58 on a part coming out of the top of the engine block. We found H4 cast into the top of the engine casting. After looking at the YouTube video of Wendell Kelch's Avery some of our parts are different. I have ask Jim to help me post some photos that hope will help us identify this tractor a little better. Does anyone know what kind and type of magneto fits this tractor? I am not sure what all we are really missing but I do know we are missing the flyball governor, the carburetor and the clutch belt pulley. Of course the big issue is the radiator. The steering mechanism was stuck but we were able to get it working and the differential shaft was also stuck. We removed one wheel and took off the drive gear. This allowed one wheel to move. The other is still stuck. It is 400 miles from home and we are hoping to get it home as soon as possible before dead of winter sets in. Thank you to all of you that have helped us identify this tractor and those who are offering parts to get it back to running condition.
Old 11-23-2014, 11:19:54 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
You likely should get in touch with Mr Tyssee at Crosby ND. He had someone make up new radiators for some of his early Averys in the past few years. Also he has a lot of knowledge about these tractors.
Old 11-23-2014, 12:24:19 PM
Smile Re: Avery Tractor Identification
A big hearty "congrats"! Look forward to watching this one progress.
Mike M
Old 11-23-2014, 07:03:12 PM
I am trying to send some photos of the tractor. I hope they come through. I have close to 80 photos of different angles of the tractor and parts. If any one can help me positivily identify the year and model of the tractor I would be glad to email them the pictures. Enclosed are mostly pictures of the numbers and letters we found on the tractor.
Thank you for all your help
Name:	306 stamped on side of engine slide frame under radiator.JPG
ID:	211562   Click image for larger version
Name:	5217 stamped on end of crankshaft.JPG
ID:	211563   Click image for larger version
Name:	5217 stamped on engine block with avery inspection plate.JPG
ID:	211564   Click image for larger version
Name:	5217 stamped on top of engine block.JPG
The Following 9 Users Say Thank You to 2030rumely For This Post:
Avery Motor Truck identification mtibesar Trucks, Trailers and Hauling for Shows 2 04-11-2014 11:56:23 PM
Avery Farm and City Tractor Caleb Carpenter Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 22 10-07-2013 06:54:56 PM
Avery 5-10 tractor PKElgin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 12-09-2011 05:53:32 PM
1919 Avery tractor richardlcoy Antique Engine Photos 0 06-03-2010 09:17:32 AM
25-50 Avery Tractor value Flyingfarm Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 10-15-2009 04:45:02 PM
