Use of Kerosene in Small Gas Engines
this thread has 20 replies and has been viewed 5449 times
Old 04-10-2018, 05:32:25 PM
OTTO-Sawyer's Avatar
Default Re: Use of Kerosene in small gas engines
Originally Posted by Vanman View Post
Water injection when burning diesel...
So a guy could add a second carburetor with no throttle plate in front of the diesel carburetor and supply it with water, and adjust it's mixture screw for best running, making the water automatic.
Kind of like 2 of the 7 carbs on the "Flaming Four" Tractor. . .
"Flying Dutchman" gives a Much Better Description of the carb set up in the comments under the video than what I 'narrated' in the video. . .
As Per His comment: It "starts on gasoline through carb #1, then runs on kerosene, distillate, or light diesel thru #4-#7, and water or water/alcohol thru #2 and #3 to control pre-ignition and add just a shade of power..."
what fuel do you run your kerosene engines on Mike Deacon Antique Gas Engine Discussion 34 10-14-2015 05:17:16 AM
Running Kerosene in old engines Rob Q Antique Gas Engine Discussion 13 07-21-2014 04:20:49 PM
Kerosene use in Maytag engines Mayatag Bob Maytag Engine Collectibles 7 08-20-2012 01:14:29 PM
Any Rawleigh Kerosene Engines ? Michael E. McCracken Antique Gas Engine Discussion 2 09-27-2011 03:20:05 PM
Galloway Kerosene Engines John Schwiebert Antique Gas Engine Discussion 8 08-20-2009 09:11:20 PM
