Tractors in December!
this thread has 73 replies and has been viewed 8832 times
Old 12-11-2015, 11:08:05 PM
elitesteamgirl elitesteamgirl is offline
Default Tractors in December!
It was a beautiful day in southern Ontario, 11C degrees (51.8F for our friends to the south)!!! We had to take advantage of the beautiful weather, so we brought our 20-40 Sawyer Massey out of the shop for the first time since we had the motor apart!
Anyone else taking advantage of the warm winter weather!?
Name:	DSC_0166 (800x536).jpg
Old 12-11-2015, 11:23:37 PM
Default Re: Tractors in December!
ESG,
First time with water in it since who knows when? No leaks save for the water pump packing which is pooped.
The ol' gal needs a little minor carb tuning then be put out in the field and work the snot out of it and get things limbered up! I think it's a keeper!??!
Oh, and new canopy - old one was wrecked when snow collapsed building on it many years ago.
The Following 4 Users Say Thank You to G Willikers For This Post:
Old 12-12-2015, 12:07:07 AM
That must be the low roof model ? eather that or the operator has grown taller.Thanks for the pictures ESG .John
Old 12-12-2015, 02:05:49 AM
GreasyJohn GreasyJohn is offline
Um cold you what I'd get the Wallis out for a pic but it's to hot to go swinging crank handles today
The Following User Says Thank You to GreasyJohn For This Post:
Old 12-12-2015, 08:15:37 AM
RobW RobW is offline
That's neat! Are you off to the shows with it next year?
The Following User Says Thank You to RobW For This Post:
Old 12-12-2015, 09:09:27 AM
Sawyer-Massey 11-22's Avatar
Sawyer-Massey 11-22 Sawyer-Massey 11-22 is offline
Location: 1851 6th. Conc. North, R. R. Stayner, Ontario Canada, L0M 1S0
Your dad phoned the other night, and mentioned the canopy. I forgot that I had, had a nice pile of 1x4 pine tongue, and groove from the late 1880's that had good air burn on one side. Probably well over 100 square feet, in 12' lengths. I bartered it off this summer. In fact he may have seen the pile when he was up with Bodo, and G. It went to a salvage friend of mine. Not sure if he still has it, or what he would likely want for it. If still there one would likely have to buy the whole lot. I can ask if he has any other t&g of similar age, and air burn. Something like that would be easy to distress, as it is almost there.
R
The Following User Says Thank You to Sawyer-Massey 11-22 For This Post:
Old 12-12-2015, 01:29:12 PM
ESG?
Do you have other photos of the tractor - different views?
This is a very solid Sawyer-Massey. Unfortunately, not much is known about its past. I remember seeing it sell at auction close to 30 years ago. It was sold at the Shillinglaw auction which was held near Uxbridge and bought by Allan Byers at Orillia. Al never did anything with it. It was shedded there but the shed roof came down after a heavy snow load and wrecked the canopy. Luckily, there was no damage to the rest of the tractor.
But what is the history from before Shillinglaws? The gearing is excellent on it so it couldn't have done too much drawbar work. There are belt pulleys on both sides, both identical with S-M parts numbers. The present owner, ESG's dad, has wondered if it was a roads dept. tractor and was set up with two pulleys to drive something like a rock crusher, elevator combination, or other such machinery? Many, if not all of the 20-40s that were saved here in Ontario had been used by counties or townships and most came from Eastern Ontario.
The Following 5 Users Say Thank You to G Willikers For This Post:
Old 12-12-2015, 07:31:07 PM
G,
This is the only other one that is up close! Will have to head out to the shop some time this weekend and take a few more. Dad might have some as well!
Name:	IMG_20151211_131919 (800x600).jpg
The Following 10 Users Say Thank You to elitesteamgirl For This Post:
Old 12-12-2015, 07:52:09 PM
Rob, Not sure if it will be at any shows, but I sure hope so!
The Following User Says Thank You to elitesteamgirl For This Post:
Old 12-12-2015, 08:35:38 PM
I could be wrong, but my understanding was that it came out of Mathews Collection in Hawkestone. I believe Bill got a number of pieces out of there.
R
The Following 3 Users Say Thank You to Sawyer-Massey 11-22 For This Post:
Old 12-12-2015, 10:43:02 PM
Here is the thread on Sawyer Massey Gas tractors.Enjoy.John
http://www.smokstak.com/forum/showthread.php?t=18576
Old 12-13-2015, 05:52:59 PM
Let's add this thread here. It was deeper than the Titanic!
R
http://www.smokstak.com/forum/showthread.php?t=29173
Old 12-15-2015, 09:22:37 PM
ESG was in the shop this afternoon (she brought doughnuts and made us tea!). She was seen measuring up for the new the canopy for the Sawyer-Massey and is going to do the lettering on the side boards for it. They should be nice.
Old 12-15-2015, 09:55:51 PM
halcon halcon is offline
And you were too busy with the doughnuts to hold the end of the tape for her.
The Following 4 Users Say Thank You to halcon For This Post:
Old 12-15-2015, 10:20:04 PM
He should have been taking some pictures for this thread instead of eating.... I mean holding those donuts.John
Old 12-15-2015, 10:26:06 PM
You fellas are quite humourous. It was a chocolate walnut crunch, made by Mennonites. You don't mess around with those things, they are to be eaten seriously and without interruption!
On a more serious subject, sometime along the way, somebody sprayed red oxide primer on some of the tractor. Anyone have hints of ways to get that stuff off easily and back to original "patina"?
The Following 2 Users Say Thank You to G Willikers For This Post:
Old 12-15-2015, 10:43:30 PM
oh!! sorry for the interruption.John
The Following 2 Users Say Thank You to casertractor For This Post:
Old 12-15-2015, 11:15:28 PM
A fairly strong mixture of sodium hydroxide will do it then rinse with water.Wear rubber gloves and eye protection. The only metal it will damage is aluminum. It makes it go away
Old 12-15-2015, 11:41:37 PM
A fine looking tractor Rick, I keep thinking I've seen a picture of a 20-40 with 2 belt pulleys running a crusher, if I come across it I'll let you know. Keep an eye on the clutch of that thing, the bigger Sawyer clutches are prone to sticking in gear, blowing apart and every other kind of fun experience once they start to wear out. A good shape clutch and transfer case are defiantly a necessity on those things.
The Following 2 Users Say Thank You to David Hoover For This Post:
Old 12-16-2015, 06:38:17 AM
David, I keep thinking the same thing, but when I went looking through photos I came up empty.
R
Vintage Ad of the Day - December Jeff Wahl Antique Gas Engine Discussion 47 12-31-2013 12:08:52 PM
November and December GEM issues Dave Rotigel Antique Gas Engine Discussion 28 11-20-2007 10:27:22 PM
