KTA M&M Minneapolis Moline Twin City Project
this thread has 94 replies and has been viewed 11318 times
Old 08-17-2018, 05:28:53 PM
Russ Hamm's Avatar
Images: 1
Default Re: KTA M&M Minneapolis Moline Twin City Project
Threshing with the KTA.https://www.facebook.com/krissysbuck...7387128211546/
Old 08-30-2018, 09:41:32 PM
Duey C Duey C is offline
Russ, did the water pump packing hang in there?
I'll go use my phone to get into faceplant. But I have to see your KTA on the thresher!
---------- Post added at 07:41:32 PM ---------- Previous post was at 07:36:21 PM ----------
Bummer! I can't get on that page. It's private or gone Russ.
Old 08-30-2018, 09:59:31 PM
MNGB MNGB is offline
The video will not come up for me either
Old 08-31-2018, 08:58:03 AM
Russ Hamm's Avatar
Images: 1
The water pump held up pretty good, still leaks a little. Looks like I will have to pack it one more time, may still have to replace the shaft.
The Following 6 Users Say Thank You to Russ Hamm For This Post:
  #85
Old 10-12-2018, 04:29:18 PM
Russ Hamm's Avatar
Images: 1
Can anyone tell me what magneto was on the KT and the KTA? I don't have a parts book, something I need to get one of these days.
Old 10-12-2018, 11:35:58 PM
Kirbster's Avatar
Kirbster Kirbster is offline
Russ
There were 3 Mags Used on the KTA
Bosch U4 Ed4
Bosch ZR 4
Fairbanks Morse RV4
Name:	MM - Kombination Repair Parts List R739F_1.jpg
ID:	320703   Click image for larger version
Name:	MM - Kombination Repair Parts List R739F_2.jpg
The Following 3 Users Say Thank You to Kirbster For This Post:
  #87
Old 10-13-2018, 12:27:50 AM
Russ, I'm glad Kirbster posted info! I wanted to know too yet couldn't help. EDIT: Oops, you did ask about the KT. I should've responded with what little I know...
Perhaps the very same mags for the Universal MTA on the assembly line. What I have is a KT owners manual and that talks about a U4 and looks to be an edition 2 by the way the wires come out of the top edge of the cap so I kept my trap shut this afternoon.
I need to look this thread over hard. Lost soul just stepping back in after far too long away.
Thanks Russ!
Kirbster, I want to come across the state and see your collection! You know the Nelson's in your area, ya?
D and N. J and his brother G? OLD show friends. I'd like to visit with you about old things.
Goll, those KT's and KTA's are so blame cool lookin'. The M's are really nice too but that K series... Uff da.
D
The Following User Says Thank You to Duey C For This Post:
  #88
Old 10-13-2018, 09:31:09 AM
Molinegb Molinegb is offline
My 30 KT has U4 and brass Stromberg m1 carb. 38 KTA has FM rv4 and Schrebler TTX. Other KTA's just parts units.
The Following User Says Thank You to Molinegb For This Post:
  #89
Old 10-13-2018, 02:29:43 PM
Kirbster's Avatar
Duey,
Funny you mention the Nelsons. I have known them since I was a teen. My first opportunity to go to shows was with the Nelsons.
The whole mag thing I did research on it until I bought a parts KTA and a American Bosch U-4 ED 4 was on it. I have included pictures of the 3 mags that Rudy at Rebuiltmag.com rebuilt for me.
The First is a Bosch ZR-4 that will be going one my 17-28 Twin City
The Second is a American Bosch U-4 Ed 2 that I had Rudy rebuild for my KTA because that is what the manual showed.
The third is the mag off the parts KTA and it is a American Bosch U-4 Ed 4. This mag is a tad bit longer and fits my linkage better, it also has a dial on the back to time it so you do not have to have the front cap off to see the rotor. Rudy showed me all the oddities to this mag.
I have the second mag pictured on my KTA right now and it is strong and starts the tractor on the first pull almost every time.
ID:	320736   Click image for larger version
Name:	AB U-4 ED 2.jpg
ID:	320737   Click image for larger version
Name:	AB U-4 ED 4.jpg
The Following 4 Users Say Thank You to Kirbster For This Post:
  #90
Old 10-14-2018, 09:15:17 PM
Gorgeous magnetos Kirbster! Question, does your U4 Ed2 have a timing adjustment lever? A hot U4 Ed1 I received from my tractor "dealer" has the same type of distributor cap and frame but no timing adjustment.
It looks like your ZR-4 should perhaps have a timing lever on the serrations.? An idled down, timing pulled back 17-28 picking them off sounds sooooo pretty!
Russ, sorry for my diversion right above^. Here's an awfully small wrinkle to add to the magneto mix and possibly another pointless, huge diversion. I pulled the mag off the shelf from my 37 MTA and found remnants of two coats of different PG paint on this American Bosch (get this) MJH 4C102 #60299.
This post is subject to scrutiny. I cannot say the mag is original to that tractor and also think the K's and Ms were assembled on the same line but have no actual clue about either.
  #91
Old 10-15-2018, 09:11:58 AM
In 1937 should be TC grey.
Old 10-15-2018, 12:25:49 PM
Kirbster's Avatar
Duey,
All my mags except the Fairbanks RV4, that I have had rebuilt from Rudy have a timing lever, Just can not see it on the U-4 Ed2
My KTA had a Bosch MJ4 mag on it when I bought it, or I should say when I
traded for it.
The U-4 Ed 2 is a slight bit shorter from impulse coupler to the points cover so my linkage didn't work, I had to make a new linkage bar for it to work properly. But the U-4 Ed 4 fits perfectly with all the original linkage I had with the tractor.
My 1935 KTA is painted about 5 different PG shades, but under all that mustard yellow is a Grey coat coming out.
As for the later KTA's Actually being painted PG 1 that's up for lots of debate, my opinion on this doesn't matter, the point that does matter if you like it the color you painted it, and it runs and not on a scrap heap, that is all that does matter.
  #93
Old 02-11-2019, 11:33:51 AM
Russ Hamm's Avatar
Images: 1
Although the KTA runs good and we threshed with it last summer the water pump shaft could really use replaced. Im thinking about tackling this soon, wondered if anybody could clue me in on the dos and donts, easy to remove? I think my packing nut is getting pretty thread worn, anybody have a good source for one? Pretty sure I can have a shaft made locally, but are ther any available? I thought maybe I read where someone had a few made.
Old 02-11-2019, 11:53:19 AM
Someone in Tx had some made. Tessman if I remember right.
  #95
Old 02-13-2019, 01:04:49 AM
Too bad they're not the same as the 21-32 water pump shaft!
Ya might also try emailing sales@molinepartsdotcom to see if he has any.
I'd been in touch (without luck) about clutch facings for the 21-32 so Charlie B's real I think.
I don't know if it'll help; jetstar.minneapolis-molinedotcom/parts
I don't know any do's or dont's but I'd expand on the VERY little experience I have on removing one 283's pump shaft and what I did on the 21-32 if you'd like.
Minneapolis Moline Twin City KTA Ben Zimmerer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 31 09-14-2015 07:34:57 PM
Minneapolis Moline Twin City 17-28 Howardh Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 06-07-2012 04:30:26 AM
Rebuild Minneapolis Moline Twin City? Janthetoolman Antique Farm Tractors 9 01-19-2012 05:31:00 PM
Twin City and Minneapolis-Moline G question Ben Zimmerer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 05-22-2011 09:24:13 AM
Moline & Twin City Carb Info Needed CharlieBiler Antique Farm Tractors 1 09-17-2006 09:56:16 PM
