Old International Harvester Literature
this thread has 9 replies and has been viewed 3647 times
Old 06-22-2010, 12:13:33 PM
hansonmo hansonmo is offline
Default Old International Harvester Literature
Folks,
I've come into possession of some old International Harvester literature. It is a 40 page booklet titled "Little Drops of Gasoline". Based on dates in the booklet I would guess it was printed around 1909 or 1910. It contains descriptions and specifications of International Gear-Drive Tractors models A through C. It also contains a bunch of letters of testimony from satisfied owners. I am not well versed in tractors of this age, nor do I know much about literature. Can anybody provide some insight about this booklet? Does it have any value? Thanks for the insight!
Old 06-22-2010, 12:45:09 PM
Default Re: Old International Harvester Literature
Some scans would probably help determine value. Definitely something this old is collectible. I tried bidding on a similar one on e-bay few months back, but didn't bid high enough. Someone would definitely want it.
Mike M
Old 06-22-2010, 01:45:35 PM
S.Simons S.Simons is offline
I live only 45 miles from Chippewa Falls, I could stop and check your booklet out for you....
Old 06-22-2010, 03:12:31 PM
Here are a couple of pictures of the booklet. One is of the cover and the other is a picture of the Type A tractor. Perhaps this will help!
ID:	81512   Click image for larger version
The Following 4 Users Say Thank You to hansonmo For This Post:
Old 01-08-2011, 07:05:49 PM
I am interested in selling the booklet but have no idea how much I should ask for it. I'd rather sell it here than on ebay. What do you think?
Old 01-08-2011, 10:45:26 PM
Use the classified section and put a number on it. I have no idea what it's worth, but you should get some interested parties!
Old 06-23-2012, 09:14:21 PM
Well.....good luck! The one I bid on on e-bay wasn't QUITE that expensive.....but maybe someone will want it that badly!
The Following 3 Users Say Thank You to Mike McKnight For This Post:
Old 08-14-2012, 10:44:45 PM
I've finally taken the leap and posted the literature on ebay. Thanks again for all your help and happy bidding!
http://ebay.com/itm/Little-Drops-of-Gasoline-International-Harvester-Gear-Drive-Tractor-Literature-/140825518762
Morgan
The Following 3 Users Say Thank You to hansonmo For This Post:
Old 08-15-2012, 12:34:22 AM
Talking Re: Old International Harvester Literature
I'm gonna stick my neck out and say I don't think you'll have any problem selling that booklet.......
Old 02-24-2019, 07:21:51 PM
Larry G. Larry G. is offline
The 2019 season for field work of International Harvester equipment is almost here. We have had enough winter weather
let's think about spring.
The Following 2 Users Say Thank You to Larry G. For This Post:
International Harvester 22-36 & W40 Kevin Watson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 01-03-2010 07:11:34 PM
International Harvester 1/5 or 3 hp 60case Antique Gas Engine Discussion 2 08-26-2009 03:44:25 PM
International Harvester LB 1 1/2- 2 1/2 Chad Schlifke Antique Engine Archives 2 11-17-2003 05:51:12 PM
International Harvester Peter Fletcher Antique Engine Archives 4 09-28-2002 10:26:55 PM
Re: International Harvester Harry Antique Engine Archives 0 03-30-2000 10:56:03 PM
