A Trip to Crosby North Dakota
this thread has 343 replies and has been viewed 91028 times
Old 06-10-2019, 02:03:58 PM
Default Re: A Trip to Crosby North Dakota
Congratulations Kelly. Are you actually old enough to be a Grampa?
Old 06-10-2019, 08:33:57 PM
Kelly Tytlandsvik Kelly Tytlandsvik is offline
Images: 407
Thank You G!
Here are a few more pictures from the weekend. Charolette Mehmkes 40-80 Avery Minus the cab. It was lost in the building failure.......that will be a later project. Another little Rumely that belonged to Charolette. It hadn't run in a few years and had one piston stuck. The guys went to work on it and freed up the stuck piston and rings....ground the valves and had it running on the weekend. That will be a video later! Tom and Matt had taken the old Polaris snow traveler back to Fargo with them last winter and had it running and rode it to a few shows. They brought it back this weekend and took its twin home with them. Scott and I got the engine back in the Flour City enough to run but I had to leave before it was started. We will finish the canopy and floorboards later. The Case power unit looks like new and is new inside!
Kelly T
ID:	336903   Click image for larger version
ID:	336904   Click image for larger version
ID:	336905   Click image for larger version
Old 06-10-2019, 10:41:56 PM
Images: 407
The Mehmke Flour City is waiting in the yard as well for some repairs after the roof collapse. The Exhaust manifold will be welded up and be as good as new. Second photo is another of Micheal and Sam Simmons making a lap with the Waterloo Boy. The Matt and the boys pulled the Avery out to fill with water and go for a test run but found a couple water leaks. They were fixing them when I left and I am sure it made some noise Sunday as well. Also not to forget about the new cars! Bud Calloway was busy cleaning carburetors and vacuum tanks on the White and the Dodge Bros. I worked a couple bugs out of the CASE Roadster. But the RAREST sight of all was Montana Slim doing something! Once the Avery, Flour City and Waterloo Boy were out of the shop "Slim" picked up a broom and began to move! And move he did..... at a snails pace....the broom seemed to weighted with Lead!
Kelly T
ID:	336914   Click image for larger version
ID:	336915   Click image for larger version
ID:	336916   Click image for larger version
ID:	336917   Click image for larger version
Old 06-10-2019, 11:01:23 PM
Images: 407
Here are a few videos from the Weekend.
Kelly T
https://youtu.be/cIV89b3PUr0
https://youtu.be/XBLCXMgxB-Y
https://youtu.be/CaiaryyYzQ0
I have a video of Montana slim but his jaw is flopping more that the broom was moving!
The Following 11 Users Say Thank You to Kelly Tytlandsvik For This Post:
North Dakota Auction Goldbug66 Live Auctions of Engines, Tractors and Old Iron 9 06-19-2013 06:38:06 AM
Crosby, North Dakota show 2008 Teeth Talk Steam Stationary Engines, Traction Engines 20 08-01-2008 01:20:50 PM
Engines from the Crosby North Dakota Show Will Batty Antique Gas Engine Discussion 0 07-23-2007 11:59:44 PM
Crosby, North Dakota show Tommygun Steam Stationary Engines, Traction Engines 14 07-17-2006 11:51:43 AM
