Galloway Air Cooled Magneto / Push Rod Trip Hole Location
this thread has 0 replies and has been viewed 249 times
Old 07-25-2018, 03:09:46 PM
bighasse bighasse is offline
Default Galloway Air Cooled Magneto / Push Rod Trip Hole Location
Hello guys, I am in the process of restoring my 1 3/4 hp air cooled Galloway. I am making a new exhaust push rod and will be making this engine into a Webster / magneto fired unit. I was wondering if anyone has an engine set up in this configuration, that could tell me the location the hole should be drilled into the exhaust push rod to mount the trip mechanism in the correct location for a webster magneto? I am not sure if the hole location makes a difference or not for an ignitor or magneto setup. If you do can you please get in touch with me at 608-558-1076 or email me at hassesurveying@wekz.net. I am planning on getting this project completed to take this engine to the Western Minnesota Steam Threshers Reunion at Rollag, MN show this year. Thank you in advance. Todd
In search of ignitor trip for 1 3/4 Galloway Kevin Loveless Antique Gas Engine Discussion 0 01-19-2016 08:41:17 AM
Galloway Trip Info Needed Mike Antique Gas Engine Discussion 1 01-27-2011 08:05:34 AM
IHC-3-5LB Crank Handle Pin Hole Location ArtLinkloader Antique Gas Engine Discussion 3 08-09-2009 06:48:23 PM
Galloway Trip Rex Pyles Antique Gas Engine Discussion 0 03-16-2008 07:01:41 AM
galloway serial number location Tim Rostar Antique Gas Engine Discussion 1 07-23-2006 06:37:06 PM
