IHC Model M Understrike Timing
this thread has 2 replies and has been viewed 467 times
Old 08-04-2018, 06:01:42 PM
Bojac Bojac is offline
Default IHC Model M Understrike Timing
Mccormick Deering 1 1/2 hp very early, L mag and ignitor, understrike. I need to time the engine. Since there is no cover (with timing marks) on the eccentric cam, how do I time the mag? Thanks for any help.
Old 08-05-2018, 03:47:36 AM
AngrySailor AngrySailor is offline
Default Re: IHC model M understrike timing
If I remember right there is a small line stamped into the end of the mag housing and on the shaft. These line up when the mag poles align with the magnets (in the middle of where itís hardest to turn, highest magnetic flux).
The ignitor should trip at this point.
Old 08-27-2018, 04:00:22 PM
Default Re: IHC Model M Understrike Timing
There will be a slash on the mag armature that aligns with a matching mark on the mag case. If you do not get the good spark, try turning the mag 180 degrees and re-try. Sometimes the marks were just slightly off. The ignitor MUST trip exactly when the marks on the mag align. This should be about 20 degrees before Top center Compression. You have to be sure the mag magnet is fully charged if the magnet is weak, you won't get fire.
3hp McCormick-Deering M timing (Understrike) Stevie Antique Gas Engine Discussion 0 10-29-2011 06:56:26 PM
JAP Model 0 Timing Delboy03 Magnetos, Ignition Coils and Spark Plugs 1 11-19-2010 08:23:06 AM
IHC Model LA Timing Paddyo Magnetos, Ignition Coils and Spark Plugs 4 05-18-2009 03:05:26 PM
IHC Model-M understrike Johnny Fermanides Antique Engine Archives 5 02-17-2003 01:43:00 PM
Timing F/M model Z mag Paul Varga Antique Engine Archives 3 02-25-2000 09:18:49 AM
