Hot Air Engines
8" Rider Ericsson Hot Air Engine
this thread has 7 replies and has been viewed 901 times
Old 08-16-2019, 02:45:06 PM
Crossley Kid Crossley Kid is offline
Default 8" Rider Ericsson Hot Air Engine
Have been after this one for a few years. Didn't think I'd get a chance to restore it.
Even came with a spare hot bulb.
So nice to find one in it's original place of work.
The Following 14 Users Say Thank You to Crossley Kid For This Post:
Old 08-17-2019, 06:31:58 AM
Default Re: 8" Rider Ericsson Hot Air Engine
The Following 8 Users Say Thank You to Crossley Kid For This Post:
Old 08-17-2019, 10:04:18 AM
Brent Rowell Brent Rowell is offline
Nice find. Looks like it's next to a river. Were you able to find out the history of its use there--for irrigation? Did it have a nameplate? Should be able to find the serial no. on one of the cranks or end of the crankshaft. Thanks for posting.
The Following 2 Users Say Thank You to Brent Rowell For This Post:
Old 08-17-2019, 02:35:09 PM
Yep got all the history I could. It used to pump water from the river to a high tank to supply the house. Does anyone sell the leathers for the pistons and the water pump ?
The Following 2 Users Say Thank You to Crossley Kid For This Post:
Old 08-17-2019, 07:12:57 PM
No one here makes leathers for Riders, but they're not hard to make using the engine's pistons and cylinders to form them. There are a couple suppliers of pump leathers.
Old 08-29-2019, 05:05:49 AM
Had to go back and pick up the engine last Sunday.
Thought a small truck would be better than a trailer due to the not so good roads.
Had it home one day and got the cold side piston out. Got the hot side soaking.
Old 09-08-2019, 05:36:11 AM
Got the hot piston out also the water pump removed and mostly stripped down. What are the check vales made of ?? Rubber Balls ??
Old 09-08-2019, 08:17:22 AM
Check valves were originally solid rubber rods. I've used polyurethane rods and I'm sure others have tried other materials.
5"? Rider-Ericsson NYEthan Hot Air Engines 13 11-23-2019 05:19:37 PM
Rider Ericsson 6" ozzienut Hot Air Engines 11 11-14-2015 11:14:36 PM
rider-ericsson 10" pumping engine Owen Holton Hot Air Engines 11 10-06-2015 10:05:38 PM
Rider Ericsson 6" ozzienut Hot Air Engines 13 07-07-2015 06:46:32 PM
Rider-Ericsson 8" Pix Patrick M Livingstone Antique Engine Archives 0 09-14-2003 08:00:30 PM
