Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Honda, Yamaha, Kawasaki, Isuszu Generators
Honda, Yamaha, Kawasaki, Isuszu Generators Restoring, maintaining and operating Honda, Yamaha, Kawasaki, Isuszu, and clones.
What Transfer Switch to use with a Honda?
this thread has 5 replies and has been viewed 845 times
Old 04-11-2018, 03:51:33 PM
plotthound plotthound is offline
Default What Transfer Switch to use with a Honda?
so ive given up on the idea of buying a generac standby generator.i now have a good eb 4000 generator thanks to everyones help here.so my question is what is the best way to power up part of the house circuits with a portable Honda generator?i don't want to be messing around with extension cords anymore.also in the near future I would like to upgrade to a Honda EU7000 inverter unit.is a generlink a decent way to go?or should I look into say a 16 circuit transfer switch?
thanks
Old 04-11-2018, 04:04:18 PM
Troll's Avatar
Troll Troll is offline
Default Re: what transfer switch to use with a honda?
Yes you should look into a small manual transfer switch to power critical power circuits from your standby generator if not large enough to carry the complete load.
Old 04-11-2018, 04:46:55 PM
billinjax billinjax is offline
I think the EB4000 has a bonded neutral. I don't know if it's easy to remove that bond in the generator. Don't know if it's a screw or if it requires hacking up some metal bonding strap. I would make sure you address this first.
I just removed a 10 circuit load side transfer switch because after a few years I realized I want more choice about what I can run. I replaced it with an interlock and backfeed breaker.
APC seems to make a fairly sophisticated manual transfer switch and Honda at some point partnered with them on the marketing. I think it can do some load shedding.
For 30A, I would use one of those meter can collar devices. Doesn't require any interior wiring and IIRC you plug the generator right into the inlet on the meter collar. GenerLink is the brand. Some utility companies will sell it and install it for you.
For more than 30A and IF my utility allowed it, I would use the PSP Transconnect version of the meter collar device. They have a semi-automatic version. It switches over once the engine is started and is outputting good power.
Otherwise, with all of my expensive lessons learned factored in, I would have wired up a service entrance transfer switch on day 1 (ASCO 185), a feeder that can support 100 A to a cheap disconnect with a small breaker, and an inlet. This way you can change to a standby generator later without much extra effort.
Old 04-11-2018, 08:11:02 PM
AlexV AlexV is offline
Generlink is a nice product. As bill said the EB 4000 has a bonded neutral. With generlink I think you need a floating neutral. The EU series has a Floating neutral so no problem there. Here's a video of one in action. https://www.youtube.com/watch?v=-mQBfHiPJTM
Old 04-12-2018, 12:29:43 PM
Default Re: What Transfer Switch to use with a Honda?
generlink looks like a decent product for sure.gotta double check to see if its legal here.after reading up on the generlink,a 4000 watt generator is not big enough to activate the switch.
thanks
Old 10-25-2019, 09:19:49 PM
tabora tabora is offline
Originally Posted by plotthound View Post
generlink looks like a decent product for sure...
I installed a 40/45Amp GenerLink with built-in surge protection (an older model) and it works fine with a 6000/7500Watt generator and provides for the future upgrade to a 10800/12000Watt unit if I decide to do so. It came with a 60' 8-gauge cable which resides on a wall mount hose reel next to the generator shed on the far side of my garage. The current generator easily handles the whole house except for the oven, secondary water heater & dryer. The larger generator would probably do everything but the oven.
Transfer Switch pnora Onan Generators 8 09-17-2014 08:02:25 AM
Transfer switch help mikeee Generators & Electric Motors General Discussion 6 08-04-2013 09:28:05 PM
OKAY, So this guy has a transfer switch... JB Tommy Onan Generators 25 09-24-2012 09:52:37 PM
transfer switch don-mar Generators & Electric Motors General Discussion 2 08-16-2009 09:52:13 PM
Transfer switch Sean W Onan Generators 3 01-04-2006 09:43:47 PM
