Go Back   SmokStak > SmokStak® General Off Topic Discussion > Smokstak Down Under
Smokstak Down Under
Re cap update Ronnie n 2hp
this thread has 9 replies and has been viewed 510 times
Old 10-02-2019, 05:37:01 AM
rustygold38 rustygold38 is offline
Angry Re cap update Ronnie n 2hp
So now after then more then 3 months it's come to and quick end after searching everywhere I could and now too tired to give a hoot for it anymore the 2hp Ronnie is forever unfinished and must move on again only wanted another water hoped or the two separate hose connector for separate pipes to a tank I'd never think so hard find eather limited folks to help around anymore oh well that's shity life for u
Old 10-02-2019, 06:05:54 AM
Rusty Engines Rusty Engines is offline
eMail NOT Working
Default Re: Re cap update Ronnie n 2hp
There was many made result parts are hard to come by
If you want to get rid of it ph Merve 47731260 as he as also being going in circles for some time trying to find parts
Old 10-02-2019, 06:08:12 AM
eMail NOT Working
Missed a word 'NOT' many made
Old 10-02-2019, 07:11:20 AM
cobbadog cobbadog is offline
Putt Putt will understand exactly what you typed Ian.
Old 10-02-2019, 04:47:26 PM
Darryl Darryl is offline
Give me the bolt hole centre to centre measurement and I’ll make two outlets so you can use a tank.
Old 10-02-2019, 05:06:00 PM
Scotty 2 Scotty 2 is offline
Don't waste your time Darryl. There are people here who have helped Putt Putt (or any of his alias's) in the past only to find it's been a waste of time. Remember the Sundex saga and all the other sagas?
Hoppers for those engines are hard to find (I've been looking for about 4 years) but Cobba asked for a picture a a suggestion for repair may be possible. Putt Putt has a hopper that simply leaks. Some 2 part putty may be the solution....
If he is that inspired to get the Ronny going, 2 outlets would be cheap to get made in Townsville. All they are is a pipe welded to a plate with 3 holes. To be honest I don't think Putt Putt has asked for the pipe outlets.
And I won't help because I'm tired of the abuse Putt Putt gives out when-ever things don't go his way.
oh well that's shity life for u. Oh no it's not Putt Putt. It's a shitty life for you.
The Following 2 Users Say Thank You to Scotty 2 For This Post:
Old 10-02-2019, 05:08:06 PM
Putt Putt's initial thread
https://www.smokstak.com/forum/showthread.php?t=189511
The Following User Says Thank You to Scotty 2 For This Post:
Old 10-03-2019, 05:09:59 AM
I know, I know Scotty, but all those Queenslanders just need to be set in the right direction and besides, it might calm the prick down.
The Following 2 Users Say Thank You to Darryl For This Post:
Old 10-03-2019, 07:24:25 AM
It is strange how the heat effects some and not others up there.
Old 10-03-2019, 04:23:05 PM
Look on Ebay in a week or so........
Re cap of Ronnie n generator engine rustygold38 Smokstak Down Under 5 08-12-2019 01:48:39 AM
Any have the PDF ronnie n Manuel? Jack5131 Smokstak Down Under 0 11-22-2016 02:20:23 AM
Ronnie n type timing issue Jack5131 Smokstak Down Under 4 12-16-2015 07:29:34 AM
Ronnie Portable Sheering plant WilliamInOz Smokstak Down Under 2 09-04-2009 04:01:35 AM
Aussie Old Iron Ronnie BTPost Antique Engine Photos 0 12-31-2005 03:42:37 AM
