Wrap-a-rope safety precautions
this thread has 15 replies and has been viewed 880 times
Old 11-14-2019, 09:35:16 PM
K-Tron K-Tron is offline
Default Wrap-a-rope safety precautions
Just a friendly reminder, make sure that your wrap-a-rope pull cord is appropriate in length for each of your engines! The pull cord on my 1949 Clinton B740 went missing and I grabbed the rope off of a Wisconsin AENL which is a longer rope made to fit on a larger diameter pulley sheave. Unfortunately I did not realize this until I wrapped the rope around the starter cup on my Clinton and gave it a pull. Before the rope fully came off the starter cup, the engine started and whipped the rope around and around, busting the sediment bowl off of the fuel tank, bending the 3/16" cunifer fuel line in two and puncturing the fuel tank. I have never had this happen to me before, and even though I thought I could quickly shut the engine down, it was too late, now I have a week worth of work to do to repair and re-seal the fuel tank, make a new fuel line and repair the damaged blower shroud.
Chris
The Following 11 Users Say Thank You to K-Tron For This Post:
Old 11-15-2019, 12:01:36 AM
ulgydog56's Avatar
Default Re: Wrap-a-rope safety precautions
food for thought....
Old 11-15-2019, 12:16:30 AM
steam and oil steam and oil is offline
Good tip.
Old 11-15-2019, 10:38:38 AM
Wow,bad news but at least you didn't get hurt.
I know we had a engine on a wood spliter at the fire department 1 night that I was cranking with a rope.And the knot came back around and caught the biggest ,baddest,former biker dude right in the ,uh,family jewels.
Needless to say I was confused as to start apologizing or running! but I knew I couldn't out run the lead he might start "tossing" my way,so I just started apoligizing.
The Following 2 Users Say Thank You to uglyblue66 For This Post:
Old 11-15-2019, 11:09:07 AM
R Towne R Towne is offline
Thanks for the safety alert. Does anyone know if there is a rule of thumb for making wrap around starting ropes of the right length??
The Following 2 Users Say Thank You to R Towne For This Post:
Old 11-15-2019, 11:14:45 AM
Due to several health problems, I use a electric drill to start all of my engines. So much quicker and safer. It is a good idea to have the engine bolted down so you don't have to chase it around the shop when it starts.
The Following 3 Users Say Thank You to EvilDr235 For This Post:
Old 11-15-2019, 03:44:43 PM
I use 2 to 3 turns around the pulley and 1/8" clearance between the rope and the slot in the starter. 2 turns should get you past at least one compression stroke, with flywheel carryover getting you past 2.. This should go for any engine. With long rope, large diameter starters like that used on wisconson engines, and for that matter any wrap a rope starter, make sure there is no one in the path of the rope as it comes off the pulley. This will at ;eat prvent whip welts and possibly injuries to eyes and the face, should a rope come loose.
Another warning, especially on larger engines, is to NOT wrap your fingers completely around the pulling handle. If the engine kicks back, it could draw your hand intoo moving parts. If you just curl your fingers around the handle, a kick back will draw the handle out of your hand, and your natural body movement will clear it of flying items. better for the engine to take a hit than your face or hands.
One other thing of note - I have seen many small engines where the debris screen has been removed. This screen allso keeps the rope out of the flywhel fins. if the rope happens to get sucked in as the engine starts, it will put a world of hurt on you as it whips around. Be safe out there!
The Following 3 Users Say Thank You to Andrew Mackey For This Post:
Old 11-15-2019, 05:51:37 PM
BernieTech BernieTech is offline
Another thought, I am working on my 23afb powered generator using gen excited start ing. The pull rope cup is sitting there spinning away. I am going to" fabricobble" a guard to keep finger safely away, after I get it fully running....
Bernie
Old 11-15-2019, 07:12:23 PM
Good tip Bernie. If that rope cup grabbed your pants leg. Ouch big time.
Old 11-15-2019, 09:12:41 PM
Ronald E. McClellan Ronald E. McClellan is online now
When I pull on the rope my hand moves back from the pulley 30". I have the other hand on the engine to steady it. At that 30" is when I want the rope to unhook and not remain on the pulley. Ron
Old 11-20-2019, 02:21:26 PM
Temp. Guard in place.
ID:	349641   Click image for larger version
Old 11-20-2019, 03:55:04 PM
JWitt's Avatar
JWitt JWitt is offline
A lesson I learned back in the 60’s on an old mini bike with an even older Lawson engine with a pulley & rope starter. Rough on the right ankle!
When in doubt, smoke em' out
Old 11-20-2019, 05:09:05 PM
Vanman Vanman is online now
This is an interesting problem I have never thought of or had trouble with. It reminds me of what can happen when you are rolling up a fish tape.
Old 11-20-2019, 05:46:33 PM
Power Power is offline
guess I missed that one. We used Greenlee. Don't recall anyone getting hurt.
Old 11-20-2019, 06:05:27 PM
Any fish tape will do it, though it’s worse if it has a leader. It happens right when the remaining tape is just the right length as it’s whipping fore and aft while being wound up. And it only effects men. And it *really* sucks. And you only let it happen ONCE. No repeat lesson required.
Old 11-20-2019, 06:55:47 PM
Any fish tape will do it, though it’s worse if it has a leader. It happens right then the remaining tape is just the right length as it’s whipping fore and aft while being wound up. And it only effects men. And it *really* sucks. And you only let it happen ONCE. No repeat lesson required.
AAh, I see. We usually did not wind them up that fast. They were personal tools- company did not provide them. I would have a rag with a little oil or grease on it, wipe and wind. Cleans dirt and makes sure you do not have a rusted tape next time you need it.
Exhaust pipe heat wrap ashwood Generac Generators (SEARS, etc.) 3 12-27-2018 08:27:04 PM
Rubber to Wrap Steel Wheels for Parade Marc L Steam Stationary Engines, Traction Engines 27 03-12-2017 06:26:20 PM
Wrap Smokstak Youtube button (Adobe Flash / Browser Problem) Brothers Clemens Computer, Camera and ISP Problems 25 08-29-2016 11:06:38 PM
Which way to wrap packing on water pump shaft? ttyR2 Hit & Miss Gas Engine Discussion 18 06-05-2016 01:15:31 AM
Muffler and Manifold Wrap Dale Russell Onan Generators 9 07-13-2015 11:26:25 AM
