Additional info for dcamp
this thread has 0 replies and has been viewed 318 times
Old 06-30-2019, 09:19:27 AM
Default Additional info for dcamp
dcamp: I am going to run the Reid for display purposes only. Engine speed will be a slow RPM. I was going to use some brand new 1/2 inch rubber air line for the connections, but if you think I need to go to a larger diameter hose, I can do that. Will be running the engine off a Wico OC magneto so no need for a second feed line to a hot tube. Will be using a 40lb brand new propane tank. I think that is all you asked for. If not, let me know through this post. Thanks
The Following User Says Thank You to Peter Holmander For This Post:
Additional Advice needed 7.5 JB YD generator end wxyoung2008 Onan Generators 16 06-19-2014 10:19:41 PM
Springfield Type A - 2hp (2 additional videos) Travis Benner Hit & Miss Gas Engine Discussion 1 11-05-2013 12:13:59 AM
WINCO Generator additional info needed avl1955 Generators & Electric Motors General Discussion 11 12-01-2011 09:43:26 PM
Additional pictures of unkown inboard. wydiver Antique Marine Engines and Outboard Motors 0 09-05-2009 08:00:29 AM
Additional photo of Olds *NM* Bill in PA Antique Engine Archives 1 07-25-2003 12:54:42 AM
