Reid 40 HP type DC compressor engine
this thread has 8 replies and has been viewed 4054 times
Old 06-22-2008, 04:33:12 PM
Tom Weatherford Tom Weatherford is offline
Default Reid 40 HP type DC compressor engine
Need info on a 40hp Reid Type DC compressor engine. Any help greatly appreciated.
Tom in VA
Old 06-22-2008, 10:32:37 PM
Ray Ethridge's Avatar
Ray Ethridge Ray Ethridge is offline
Default Re: Reid 40 HP type DC compressor engine
Tom,
They have one at the Temple show in Texas. It has run every year I have been there except last year (air line problem I heard) so someone there knows how to run it. I will see if I can find out who might know about it.
Ray Ethridge
Name:	big Reid at Temple.jpg
The Following User Says Thank You to Ray Ethridge For This Post:
Old 10-17-2008, 09:01:03 AM
Bob Stadler Bob Stadler is offline
Tom in VA
Interesting photo I have seen these engines laying around some oil fields in western Pa. years ago. I had purchased and now in the process of restoring to sell a 12 1/2 by 16" Reid that looks very much like your engine. The data I gathered years ago on this engine that it is a 95 hp at 550 rpm but this was from the modification done by the oil field owner making it a 13 1/4 x 16, he said thatthey were made to be interchangable. Just change the cylinder/water jacket and head. My lubricater is slightly different along with the air shut off system that comes directly from the "distributor" (the mechanical device that derives its power from a shaft that comes the crank), also my magneto is different. I am somewhat at a loss on how the pressure/temperature cutoff switch works if in fact that is what it is. I will try to attach photos. By the way nice flywheel paint job.
Bob
ID:	41748   Click image for larger version
ID:	41749   Click image for larger version
ID:	41750   Click image for larger version
The Following User Says Thank You to Bob Stadler For This Post:
Old 10-18-2008, 09:00:28 PM
Here ia a pic of one still "in the wild" Bill Klein
Name:	Reid Single Fry building.JPG
The Following User Says Thank You to W.P.Klein For This Post:
Old 10-19-2008, 07:44:49 AM
DanR
Watch out Tom. That short stack is going to blow the roof off your shed.
Old 10-27-2008, 06:56:25 PM
Short Cut Short Cut is offline
The Temple show...You need to talk to Monk Ivicheck (sp?). He does not own the engine but knows all about it. He knows and owns more old iron that most of us have dreamed about.
Old 10-28-2008, 05:08:48 PM
Just how might I get in touch with Monk?
Tom
Reid plunger type water pump Ray Ethridge Oil Field Engines & Related Equipment 7 10-20-2008 03:10:02 PM
Reid "sistersville" type? Ray Ethridge Oil Field Engines & Related Equipment 21 11-17-2007 07:22:24 PM
Compressor oil type? Renee Machine Shop and Tool Talk 11 09-22-2007 08:49:07 PM
Engine to Air Compressor Frank Douglas Small Air Cooled Gasoline Engines 2 05-21-2006 02:43:25 PM
Reid type A Bill Klein,Pa Antique Engine Archives 6 10-01-2002 01:55:28 AM
