Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Fairbanks Morse torch head at Temple, TX 1995
this thread has 4 replies and has been viewed 2407 times
Old 05-28-2012, 11:51:24 AM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
Default Fairbanks Morse torch head at Temple, TX 1995
Here is a video that is a bit shaky. It was taken on VHS back in 1995. I'll type in details later if the video up loads correctly.
Old 05-28-2012, 08:25:18 PM
Default Re: Fairbanks Morse torch head at Temple, TX 1995
This engine came out of a cotton gin in Seaton, TX. It was donated by the family off the owner in 1995. The only stipulation was it had to be moved in the next few weeks as they were building a house on the propery and the gin was in the way.
I went down on a Saturday with my haul truck and two employees. We met Bradley Ware there with the gin pole winch truck. After some work we got the bolts out of the clutch/flywheel and got the line shaft out of the way. We took the tin off of the building and got the engine loaded about dark. We spent the night and headed home early the next day. It was a 200+ mile trip with and overloaded truck but we got home without any problems.
I unloaded the engine on railroad cross tie cribbing and began working on it. It was stuck and had two large rat carcasses in the exhaust y and some fruit bat remains in the crankcase. After many weeks of work I determined it was ready to run. I piped air to the air start valve with PVC pipe. I called my uncle Bully to come up and help. We got the Kerosene torches lit and got the heads good and hot. After a few times through it hit and went to running. The vibration broke the pvc fitting and all the compressed air came up my pants leg. I joined the bird gang(as in flew the coup). I left my uncle there with both injector levers trying to shut the engine off. We decided it would not be a good idea to start it again on the cross ties.
I hauled the engine back to Temple and poured the concrete foundation for it. The video is the day before the show in October of 1995. I am the thirty year old with overalls and my late uncle James (Bully) Fuller is adjusting the fuel.
The Following 7 Users Say Thank You to Dwayne Fuller For This Post:
Old 05-29-2012, 12:06:13 PM
kwfiggatt kwfiggatt is offline
In the video, it looks like the engine loads up and then coasts for a while - somewhat like hit and miss governing. Were you guys doing this, was the governor out of adjustment, or is it supposed to do this?
Thanks,
Kevin
Old 05-29-2012, 01:47:36 PM
Dustin D Ehli Dustin D Ehli is offline
Images: 15
Cool, thanks. Sounds like she is only hitting on one in the later part of the video.
Having a blast preserving the past.
My Youtube Channel
Old 05-31-2012, 09:20:31 AM
Thanks,
Kevin
That was my uncle cutting the fuel out then back on to make the engine hit hard and come back up to speed. It actually runs very steady on the governor when it gets warmed up. Some of the stuff may have been out of adjustment as this was before we had any literature on this engine.
Yes on that first run we were having problems with one of the injectors. We got it sorted out before the show opened and the engine ran great all weekend.
The Following User Says Thank You to Dwayne Fuller For This Post:
Fairbanks Morse Kerosene Torch for the "YH" Help! J.R.Smith Vintage Diesel and Oil Stationary Engines 13 02-06-2015 09:48:39 PM
Fairbanks Morse Cylinder Head Spenser and Dave Rynne Hit & Miss Gas Engine Discussion 7 08-25-2011 06:42:36 AM
Wanted info on 1907 Fairbanks Morse 5 HP Torch Ignitor majuro Hit & Miss Gas Engine Discussion 9 03-05-2010 06:52:47 PM
Fairbanks Morse Head part number Stevie Hit & Miss Gas Engine Discussion 0 03-18-2008 09:53:44 PM
Fairbanks Morse 3kw generator Head ZackaryMac Generators & Electric Motors General Discussion 7 01-24-2007 10:49:47 PM
