Onan 12.5jc water in fuel
this thread has 8 replies and has been viewed 1435 times
Old 06-04-2013, 07:00:24 PM
rodymartin rodymartin is offline
Default Onan 12.5jc water in fuel
The grandkids left the top off the gas tank and it now has water in the carb. what is the best way to deal with this?
Old 06-04-2013, 07:30:35 PM
Default Re: Onan 12.5jc water in fuel
Tell your son/daughter to make sure grandkids leave your stuff alone.
Drain the tank, remove the carb bowl, and flush the lines as best you can. Put back together and add a small amount of fresh fuel. Run the set, expect it to stumble and sputter a little bit at first. If it runs OK, fill the tank. Secure gas cap so grandkids can't fool with it.
Save the water contaminated gasoline in case you need it for son/daughter's car in case they fail to get the message across effectively to grandkids.
The Following 3 Users Say Thank You to Wayne 440 For This Post:
Old 06-04-2013, 07:49:52 PM
Unhappy Re: Onan 12.5jc water in fuel
How to get the carb bowl off with out taking the carb off?
Old 06-04-2013, 08:16:50 PM
For the (spec AA) JC I have, the carb bowl is held on by the main jet. Removal is very simple - screw out main jet needle, place in a safe area. Loosen and remove the main jet, and the bowl will come right off.
Yours may be different.
Old 06-04-2013, 08:55:04 PM
rmchambers rmchambers is offline
Can you remove the whole jet assembly without messing with the main jet? that would be easier than having to re-lean the mixture again.
Old 06-04-2013, 09:08:34 PM
You can, but I have broke a needle valve off before by doing so; thus, I do not do so now.
Old 06-04-2013, 10:25:06 PM
len k len k is offline
I don't know your carb , but all the carbs I played with are easier to remove and clean them in your hand. Less chance of bending things, like the float. Plus if you just take it off you can also disassemble it more to give it a good cleaning. Carbs always seem to need a little cleaning.
The Following 3 Users Say Thank You to len k For This Post:
Old 08-03-2013, 01:19:07 AM
Cleaned the carb and reassembled it. completely draned the fuel system. Now it runs better than ever did. But I have a electric fuel pump to keep it running. Where is the best place to hook up the wire to shut it off when I shut off gen set?
Old 08-03-2013, 06:22:52 AM
Gunny Gunny is offline
Pick up power for it on the hot side of the ignition coil.
Coil has (3) wires. One is the high voltage cable to the middle of the distributor, another small wire runs to the side of the distributor. One wire runs from the coil to the control box. Use that wire as the power source for the electric fuel pump.
The Following User Says Thank You to Gunny For This Post:
lister fuel and water problems lilfatchef Vintage Diesel and Oil Stationary Engines 7 08-23-2011 12:33:24 PM
25 40x Rumely fuel & water tanks Rod Gaffrey Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 08-20-2011 10:10:34 AM
Onan 30EK city water model water pump impeller? Pete Spaco Onan Generators 9 06-12-2011 02:36:49 PM
Installing CAT fuel water separtor Isaac-1 Generators & Electric Motors General Discussion 2 06-23-2010 05:23:56 PM
