Wico EK question
this thread has 6 replies and has been viewed 1715 times
Old 08-15-2013, 09:21:08 PM
SteveK SteveK is offline
Default Wico EK question
This mag has worked great for the 20+ years I have owned it. This year however it wouldn't run my engine. Here is what I know, I cleaned the oil film off the pole ends and filed the points and gapped them. It now will throw an 1/8 inch spark but no more. I noticed when the spark gap gets too big I see orange spark at the contacts. Also the plug wire contact on the left coil looks like it has been clocked wrong for years. The internals appear to be all original. Should I just do points and condenser or coils also. Magnetism feels plenty adequate to me.
Steve
ID:	172360   Click image for larger version
ID:	172361   Click image for larger version
On the level
Old 08-15-2013, 09:35:19 PM
Junkologist's Avatar
Default Re: EK question
Fire at the points generally indicates a bad condenser.
Mike
SmokStak member #146
Old 08-15-2013, 09:35:23 PM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
Steve I would try a new condenser and see if that makes a difference.
Old 08-16-2013, 08:41:01 PM
Dempster Dempster is offline
Orangish yellowish spark at points means the condenser is leaking and failing. Insulation in it is shot.
Old 08-16-2013, 11:03:43 PM
well tonight I put a new condenser in it and the same thing... weak 1/8 spark and any bigger on the gap causes sparks at the points. So I completely tore it apart and replaced everything. It now has more reliable spark but still weak, I tried it on the engine, nothing...... So I put my other ek on the engine and it started first try. At that point I put both mags on the bench and started to compare them. The mag that works I can not pull the armature off, too much magnetism. The failing mag I can so I am guessing the magnets are weak in the knees. Time to build a magnet charger..........
On the level
Old 08-17-2013, 09:03:38 AM
Default Re: Wico EK question
Bring it up I will charge it for you.
Old 08-17-2013, 08:25:33 PM
ok will do.
On the level
WICO EK Question Bryxtreme Magnetos, Ignition Coils and Spark Plugs 3 03-29-2013 09:34:55 PM
Wico EK Question Chris F. Morris Magnetos, Ignition Coils and Spark Plugs 1 10-25-2009 10:42:48 PM
Wico question Acre Farm Small Air Cooled Gasoline Engines 7 12-30-2006 11:57:58 AM
WICO question Tom Winland Antique Engine Archives 7 07-15-2003 02:02:19 PM
Wico EK question Tom Antique Engine Archives 2 06-30-2003 12:55:24 AM
