Smokstak Down Under
Bessemer 12hp
this thread has 6 replies and has been viewed 2004 times
Old 01-23-2014, 08:33:19 AM
typak typak is offline
Default Bessemer 12hp
Here's the latest addition to the collection a 12hp bessemer half breed,steam bed 1880's Innis. The gearless pendulum governor and slide valve transfer port is a unique approach to governing a engine,keeps a constant volume in the charging side of the cylinder so no strokes are missed. It ran well at the north coast rally last weekend and easy to start,thanks to every one who helped with this one.
Kim.
ID:	185689   Click image for larger version
ID:	185690   Click image for larger version
ID:	185691   Click image for larger version
Old 01-23-2014, 08:46:19 PM
Default Re: Bessemer 12hp
Kim.
Very nice!!
The Following User Says Thank You to Kirk Taylor For This Post:
Old 01-23-2014, 11:15:54 PM
Rod Fielder Rod Fielder is offline
does it have a patent date on the cylinder. 1898-99? they only made 2000 total in 98-99
The Following User Says Thank You to Rod Fielder For This Post:
Old 01-24-2014, 06:26:56 AM
Hi Rod,
There's no scripting on the cylinder at all,only on the clean out cover on the head is "12 HP" , however on the top machined surface of the cylinder support leg and opposite on the bottom of the cylinder is stamped #456. The bed plate has some of the Innis paint and pin striping on it, have not found a number on it yet.
Kim.
The Following User Says Thank You to typak For This Post:
Old 01-24-2014, 06:35:35 AM
Here is a clip of it running.
http://youtu.be/Ciq6xxJ6J2k
Patrick
The Following 6 Users Say Thank You to Patrick M Livingstone For This Post:
Old 01-25-2014, 02:27:43 AM
cobbadog cobbadog is offline
How sweet it is ! What a lovely running and sounding engine it is.
Looks like the oiler on the small end bearing was turned off.
Old 01-25-2014, 08:18:26 AM
Yes, sweet they are,it takes a little tinkering to get them to run nice.The small end oiler is a manual greaser just give the T handle a turn before starting,auto greaser on the big end.Only thing that sounds better is a well tuned Reid !
The Following 2 Users Say Thank You to typak For This Post:
Associated 12hp Associatedboy Hit & Miss Gas Engine Discussion 6 07-31-2013 07:51:42 PM
12hp Bessemer Ruined Steve Tachoir Oil Field Engines & Related Equipment 37 11-11-2008 12:41:12 AM
12HP Bessemer bearing pics / size Tremel Oil Field Engines & Related Equipment 2 09-06-2006 09:53:54 PM
Bessemer 12hp Jim Huggans Antique Engine Archives 0 11-19-2003 09:23:58 PM
12hp R&V Finished Patrick M Livingstone Antique Engine Archives 0 02-07-2002 11:43:38 PM
