Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Fairbanks Morse Y-H 25 HP Diesel Sight Glass Replacement
this thread has 12 replies and has been viewed 1756 times
Old 09-04-2015, 02:17:05 PM
Peter Holmander Peter Holmander is offline
Default Fairbanks Morse Y-H 25 HP Diesel Sight Glass Replacement
Has anyone ever had to replace the sight glass on the main bearing on a Fairbanks Morse 25 HP Y-H Diesel? Was wondering how they come out and where I can find a replacement glass. One of mine is broken. I'm thinking glass boiler tube would work.
Old 09-04-2015, 03:41:29 PM
ArtLinkloader ArtLinkloader is offline
Default Re: Fairbanks Morse Y-H 25 HP Diesel Sight Glass Replacement
Unscrew the slotted plug, gasket and insert glass, replace plug. Art.
COAL
GUNS
FREEDOM
Old 09-04-2015, 04:21:18 PM
Thanks Art. I saw the threaded holes over each sight glass, is that where the plugs are. They are full of dirt right now.
Old 09-28-2015, 01:37:45 AM
Chuck Moss's Avatar
Chuck Moss Chuck Moss is offline
Sounds like your plugs may be missing, but that shouldn't be hard to make. If I remember correctly, the plug has a vent hole drilled through it.
Once the plug is removed, if it is there, then the glass should lift out once the area is cleaned out. No real magic, just straightforward old school design. My 10 HP glass was not broken so I don't know what size, but diameter probably OK plus or minus some just as long the bottom of the tube fits to the gasket. Length needs to be long enough so the plug pushes down on the glass to form the seal at the bottom.
Chuck
The Following User Says Thank You to Chuck Moss For This Post:
Old 09-28-2015, 08:00:47 AM
48bomber 48bomber is offline
Peter
Where Is the pictures as you work on your engine?? You know we want to see!!
Andy
The Following User Says Thank You to 48bomber For This Post:
Old 09-28-2015, 09:49:30 AM
Hi Andy. I'll have to try to post a few pics. I bought a trailer to mount it on and have been working on getting the oak all drilled so I can bolt it down. One of the sight glasses is broken and the other looks like it was leaking so those will definitely have to be replaced. How's it going with the tray cooler for yours?
Old 09-28-2015, 06:27:44 PM
Still waiting for the trays....
So mine has likely similar glass sight gauges. The threaded plug holds the glass in. I replaced the gasket top and bottom with a thick gasket from the auto parts store. Works perfect. The screw plug was also vented and that's how the moisture was showing up on the inside of the glass. A cover over them fixed it.
Don't forget those pictures!
Old 10-09-2015, 03:58:54 PM
Please bear with me guys, my first attempt at posting pictures. Here are two of when I first brought the engine home.
ID:	236494   Click image for larger version
The Following User Says Thank You to Peter Holmander For This Post:
Old 10-09-2015, 04:03:38 PM
Two more pictures of it on my lift removing the steel it was sitting on to get it ready for oak.
ID:	236496   Click image for larger version
Old 10-09-2015, 04:07:05 PM
And the last two pictures of the engine on oak all bolted down to the dedicated trailer I bought for it. Now the fun begins, going all through it and checking everything out before I try to run it.
ID:	236498   Click image for larger version
Old 10-09-2015, 06:47:16 PM
Bloppy Bloppy is offline
Nice! Looks like a fun winter ahead.
Jim
The Following User Says Thank You to Bloppy For This Post:
Old 10-09-2015, 09:59:01 PM
Looks real good! The heavy stuff looks done now that it is on the trailer!
You have mastered the picture posting thing so don't forget us!
Old 10-10-2015, 07:26:44 AM
Thanks guys !! When I was trying to find a FM Diesel I could not find anything local to me. They exist, but no one wanted to sell. I missed out on a running engine in Florida through an email miscommunication. This engine came from Idaho and I had it shipped via truck to me. I cannot thank Lauren Langdon enough for going out of his way to help me procure this engine. For those of you who don't know Lauren, he is the proud owner of the FM Take-apart engine whose restoration was covered in great length here on this website. I still have my heart set on a FM Y 37 1/2 vertical. If I live long enough, eventually I will own one of those too.
New Sight Glass WisconsinSteam5443 Scale Model Engineering 9 12-24-2013 06:08:05 PM
Sight Glass: How's it cut? WisconsinSteam5443 Steam Stationary Engines, Traction Engines 16 05-23-2012 11:27:38 AM
sight glass workhorse Steam Stationary Engines, Traction Engines 7 03-20-2007 08:12:51 PM
Sight glass Andrew Steam Stationary Engines, Traction Engines 2 10-26-2003 10:55:14 PM
Sight Glass Russell Gilbert Antique Engine Archives 0 06-24-2000 08:25:02 PM
