Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
Steam engine half breed
this thread has 5 replies and has been viewed 1033 times
Old 01-17-2017, 12:44:35 AM
Randy L Peterson Randy L Peterson is offline
Default Steam engine half breed
Just curious if anybody has made a scale model steam engine and made a 2 stroke or 4 stroke. Cylinder and made it run like a half breed.
Randy L Peterson
Old 01-17-2017, 01:20:21 PM
Default Re: Steam engine half breed
Randy L Peterson
Randy,
That's an idea I've been pondering as of late especially since the Bessemer models are no longer available. This Innis conversion,
https://www.smokstak.com/forum/showthread.php?t=165352
would make a really neat model.
Kirk
The Following User Says Thank You to Kirk Taylor For This Post:
Old 01-17-2017, 01:20:33 PM
Burns & Horner made a Bessemer 2 stroke model - not a conversion. I have been looking for one for years. If you were to build a conversion from a steam engine, the biggest issue would be the flywheels - they would have to be heavy enough to carry the engine over the compression stroke. if you look at the full size OIL City - South Penn conversion engines, you will see that SP added a heavy flywheel for that purpose - the steam flywheel is way too light to do the job on its own.
Old 01-17-2017, 01:36:45 PM
Model I have is an old Stuart #9 kit. Has a big flywheel piston Bore size is 1 1/2
Old 01-17-2017, 02:12:46 PM
If I'm reading this right , you want to make a two stroke steam engine. That is nothing new , It is called single acting. A four stroke steam engine can be done but makes no sense because it would only have power every two revolutions. Most steam engines have power two times in one revolution. Ron
Old 01-17-2017, 02:40:27 PM
I want to make an internal combustion cylinder for it. Convert it from steam to a gas engine like some of the old oil field engines. And have the Steam cylinder if I want to bolt that on and run it as a steam engine as well.
Tillinghast half breed oil field engine Paula Freeman Oil Field Engines & Related Equipment 9 05-31-2016 07:15:10 AM
A different kind of half breed engine Bill Hazzard YouTube Old Iron Videos 0 05-27-2012 10:59:36 PM
Boiler help for half breed steam engine the-mitchster Vintage Toy Steam Engines and Motors 5 11-19-2009 06:39:04 PM
Oil City Half Breed Engine john_deere Oil Field Engines & Related Equipment 6 07-21-2008 01:55:23 PM
Half breed engine Andrew Mackey Oil Field Engines & Related Equipment 3 07-28-2006 10:14:44 AM
