Oil Field Engines
Hot tube burner and chimney for 30 hp Reid
this thread has 4 replies and has been viewed 3151 times
Old 04-15-2008, 11:07:16 PM
JHFoster JHFoster is offline
Default Hot tube burner and chimney for 30 hp Reid
My mag crapped out today and I can not seem to fix it. In a pinch I need to run the hot tube, I have a tube but no burner and chimney. Is there a quick fix? It need to run this weekend. Thanks, Jeff
Old 04-15-2008, 11:49:23 PM
LCJudge LCJudge is offline
Default Re: Hot tube burner and chimney for 30 hp Reid
Got an acetylene torch? If so, rig it somehow (C clamp it, wire it, etc) to heat the hot tube and it will run. The purpose of the chimney is to maximize the heat, cover the flame, etc. It will work without the chimney, it will just take more heat to keep it red than if the the chimney were present.
Tommy Turner
The Following User Says Thank You to LCJudge For This Post:
Old 04-16-2008, 08:40:47 AM
Tom Winland's Avatar
Tom Winland Tom Winland is offline
Banner Sponsor
Images: 8
You can make a chimney with some pipe and get a needle jet at the hardware store and mount in the side of it at the bottom. you'll have to drill a series of holes around the bottom of the pipe to allow air in though.
Tom Winland
Ohio
Old 04-16-2008, 11:13:49 AM
Ray Ethridge's Avatar
Do you know anyone that has a gasoline blowtorch you could borrow? That would make a really neat setup!
If you would like to borrow my setup for the weekend I could get it to you tomorrow via ups. Just put a propane bottle on it and you are ready to go. Call me 979 451-0940 if you are interested. I will be going through there in a couple of weeks to pick up some engines so I could pick it up then.
Ray Ethridge
Old 04-20-2008, 11:31:06 PM
Exclamation Re: Hot tube burner and chimney for 30 hp Reid
For the long term, John Burns has tubes and burners, as well as torches for the Reids. Look him up on the sponsor page
Asbestos liner for Hot Tube Chimney Jim Gorter Oil Field Engines & Related Equipment 5 08-17-2006 09:56:25 PM
Weber 5 HP Hot Tube chimney Wayne Grenning Hit & Miss Gas Engine Discussion 6 04-28-2006 11:46:51 PM
asbestos for hot tube chimney Coolhand Luke Hit & Miss Gas Engine Discussion 6 03-30-2005 08:32:30 AM
Hot-tube Chimney Greg Mosley Antique Engine Archives 4 09-02-2004 10:36:30 PM
Hot tube chimney liner Tom Winland Antique Engine Archives 0 08-29-2001 09:44:11 AM
