Oil Field Engines
2HP? Buffalo Olin
this thread has 2 replies and has been viewed 1591 times
Old 07-02-2010, 01:59:20 PM
Brian Lynch's Avatar
Images: 23
Default 2HP? Buffalo Olin
Just recovered this one. Methinks it's a 2 hp. All it's missing is the oiler and mag. The mag setup shown is for an Wico EK, and I think it may be a factory retrofit. It is outfitted with natural gas mixer. Very good compression and all bearings are tight with lots-o-shims left. Can anybody make sense of the serial number? It is stamped into the frame just in back of the cylinder.
Name:	Buffalo Olin 1.jpg
ID:	82139   Click image for larger version
Name:	Buffalo Olin 2.jpg
ID:	82140   Click image for larger version
Name:	Buffalo Olin 3.jpg
The Following 12 Users Say Thank You to Brian Lynch For This Post:
Old 07-02-2010, 04:00:16 PM
Tom Winland's Avatar
Tom Winland Tom Winland is offline
Banner Sponsor
Images: 8
Default Re: 2HP? Buffalo Olin
Very nice
Tom Winland
Ohio
http://gasenginetom.com
CHECK OUT MY ENGINE VIDEOS AT
http://www.youtube.com/user/gasenginetom
The Following User Says Thank You to Tom Winland For This Post:
Old 07-02-2010, 04:39:37 PM
Images: 23
Just talked with a good pal of mine and he says it is a 4 hp Olin. The magneto trip system is a field conversion from the factory.
UPDATE: 5:10 PM July 2, 2010. We had it running for a few minutes on propane. Needs a few gaskets & a water tank hooked up. Then I can fine tune it.
Buffalo Olin Gas Engine 6 1/2 hp Jeff R Parks Antique Engine Photos 0 08-12-2007 10:12:38 PM
28 hp Buffalo Olin Gas Engine Video Jeff R Parks Antique Engine Photos 1 03-20-2007 12:28:10 PM
5 HP Buffalo Olin Pix Craig Prucha Antique Engine Archives 0 04-29-2004 06:09:10 AM
Olin Gas Engine, Buffalo NY Jeff Parks Antique Engine Archives 0 10-21-2002 09:54:48 PM
5 HP Buffalo Olin Vertical Craig Prucha Antique Engine Archives 0 06-05-2002 07:50:21 AM
