Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
lister fuel and water problems
this thread has 7 replies and has been viewed 2320 times
Old 08-22-2011, 01:55:30 AM
lilfatchef lilfatchef is offline
Default lister fuel and water problems
Lister FR3 HELP, I am in need of advice i have diesel in the coolant and vice versa i am guessing the fuel filter has a split in it can i divert the fuel through an external filter and seal the fuel unions or is rhe engine us many thanks
lilfatchef
Old 08-22-2011, 02:57:38 AM
ListerDiesel's Avatar
Default Re: lister fuel and water problems
Very common on the FR, the casting between the fuel filter and the water jacket fractures when frosted and you have problems.
Nothing stopping you fitting a Lister CS or other external filter, you need to make sure that the old filter housing connections are fully blanked off so water cannot leak out.
Peter
The Following User Says Thank You to ListerDiesel For This Post:
Old 08-22-2011, 03:05:21 AM
thank you for your reply peter. engine also overheats will this also stop if i block all unions
Alan
Old 08-22-2011, 03:14:30 AM
Ironsides Ironsides is offline
Alan,by overheat what temperature roughly are you talking about?Most problems I have encountered on diesels is through running too cold.Near to boiling shouldn't be a problem,what about showing us a photo of the tank/hopper on her and also what are you driving with her when she gets hot,keep cranking,Norm
Old 08-22-2011, 04:00:37 AM
she is a keel cooled engine with a large gravity fed fuel tank she did not boil or sieze just got hot and pushed water into fuel tank she is in a 1935 wooden narrow boat
thanks
Alan
Old 08-22-2011, 05:21:19 AM
eddie bedwell eddie bedwell is offline
Hi lilfatchef,
by keel cooled I take it you are refering to a closed system with the coolant being passed thru cooling pipes outside the hull.
Some things to consider would be :-
Marine growth covering these pipes can inhibit heat transfer. The pipes have been squashed thereby inhibiting water flow.
Failed thermostat, if fitted.
Or water pump problems, ie impeller/housing eroded, Collapsed rubber inner plys in the connecting hoses etc.
Hope this helps.
Cheers,
Eddie B.
Old 08-22-2011, 06:38:46 PM
Hi Alan,
provided the engine does not have issues with head gasket leaking etc. some further cooling system tests to determine the type of cooling system problems are:-
check the temperature difference of the coolant going to the cooler versus the coolant return temperature.
If the temp. diff. is small then you have good flow but little cooling by the cooler.
If temp. diff. is high (over 15#F) then you have low flow rate of coolant thru the cooler.
Cheers,
Eddie B.
The Following User Says Thank You to eddie bedwell For This Post:
Old 08-23-2011, 12:33:24 PM
Thanks peter worked a treat
Alan
Problems with Lister Electronic Governor CatMan Generators & Electric Motors General Discussion 5 10-15-2010 01:53:31 PM
1 1/2 understrike type M water problems Keith Johnson Hit & Miss Gas Engine Discussion 4 05-09-2010 07:46:48 PM
2.5lk-1r fuel problems blslkn Onan Generators 8 09-03-2009 08:03:40 PM
Water Pump Problems TIM Hit & Miss Gas Engine Discussion 4 10-08-2007 07:20:31 PM
