WINCO Generator additional info needed
this thread has 11 replies and has been viewed 2247 times
Old 11-23-2011, 07:57:05 PM
avl1955 avl1955 is offline
Default WINCO Generator additional info needed
finally found an experienced electrician (with generators) to trouble shoot my unit...for some reason the unit decided to return from vacation and work...he did determine that it was over producing voltage..around 250V...Questions...will RPM's affect output? this is a single cyl 16 hp.supposed to run at 3600 RPM...what kind of meter(tach) do i need to determine current RPM's...this unit was orig run on nat gas, now runs on propane...are there any other adjustments needed for the difference in fuels...the installer did make adj's to the gas regulator at time of install...he did not make any adj to govenor...any help greatly appreciated..thanks and have a great holiday
Old 11-23-2011, 08:01:48 PM
ehpower2's Avatar
ehpower2 ehpower2 is offline
Default Re: WINCO Generator additional info needed
check the tags it might run at that voltage or maybe it runs at 1800 voltage. how are the hertz
Old 11-23-2011, 08:05:45 PM
K D Redd K D Redd is offline
Find/buy a Kill-A-Watt meter. they read HZ, Volts, Amps, Watts, and Kilo-Watt Hours. You can buy them for 25 to 30 bucks.
Kent
Old 11-24-2011, 06:25:04 AM
is the kill-a-watt meter an item that plugs into a socket ? when using this item,would i then lower rpm's to get within 220/230 V or the HZ to the 60/61 range ? what is more important, hz or volts within a specific range or does one affect the other ...sorry for all the questions...i know very little about the science of electricity...thanks again to all that help...it is much appreciated..
Old 11-24-2011, 08:01:19 AM
armandh armandh is offline
on many generators with uncomplicated VR, YES the hertz [speed] needs to be correct and stable for the correct output voltage!
Old 11-24-2011, 11:04:02 AM
First set the speed/HZ to 62 HZ unloaded. Then measure the voltage. It may be a little high because there is not a load on the generator. If the voltage is under 135 volts on the 120 side I would say your are good to go.
Kent
Old 11-24-2011, 11:29:46 AM
i will go find a kil-a-watt on friday....will go from there...again, thanks....
Old 11-27-2011, 12:33:55 PM
found a kilo-watt on sat...shut off eveything in my sub panel except 1 outlet...initial start up unit producind 130.9 V,63.6 HZ...brought engine speed down so outlet showed 121 V,58.9 Hz..if engine speed is increased so unit produces 62 Hz as advised,outlet is producing 125 V.are these numbers within safe operating range, or should i look at having internal adjustments made if this is possible?appreciate all the help...thanks again...
Old 11-27-2011, 02:37:05 PM
In a word, YES.
Kent
The Following User Says Thank You to K D Redd For This Post:
Old 11-28-2011, 08:13:53 AM
yes to the former part, it seems ok
now add load to about half the capacity
heaters, toasters, hair driers, whatever
and adjust to 60 hz, recheck voltage
Old 12-01-2011, 06:00:25 PM
thanks to all for the help getting my unit operating properly...have a pleasant hoiday...see you next time i am in a mechanical crisis....
The Following User Says Thank You to avl1955 For This Post:
Old 12-01-2011, 09:43:26 PM
Lloyd H Lloyd H is offline
Thanks for the followup report. We especially like success stories.
info needed for beltdrive Winco generator Chris Schmidt Generators & Electric Motors General Discussion 5 12-24-2011 09:20:43 PM
WINCO standby generator parts/info needed avl1955 Generators & Electric Motors General Discussion 5 12-17-2011 11:00:51 PM
Winco Info needed David Swanson Generators & Electric Motors General Discussion 0 02-24-2002 07:37:04 PM
Winco Info needed Zira Generators & Electric Motors General Discussion 0 04-28-2001 09:15:49 PM
Winco Info Needed Zira Generators & Electric Motors General Discussion 1 04-17-2001 12:56:55 PM
