Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
OLD Mini Gas Tractor Model Ignition help needed
this thread has 9 replies and has been viewed 692 times
Old 04-29-2019, 05:10:06 PM
ctmouse ctmouse is offline
Default OLD Mini Gas Tractor Model Ignition help needed
ID:	333697 Click image for larger version
I have this old toy gas tractor I want to get going again. It has a lawn mower coil used for the ignition and a condenser along with a set of points. It had spark while I was using a very small 12 volt battery but I burnt out the coil and no spark now. I want to know can I use a 12 volt car coil and condenser and the small 12 v battery to provide the spark to the NKG CM-6 spark plug? or if anybody has more information on what I may need to get this to fired up that would be great as this is a driving toy tractor with both forward and reverse. Thanks everybody!
ID:	333700   Click image for larger version
The Following 8 Users Say Thank You to ctmouse For This Post:
Old 04-29-2019, 08:16:21 PM
Jeff Wahl's Avatar
Jeff Wahl Jeff Wahl is offline
Default Re: OLD Mini Gas Tractor Model Ignition help needed
Neat model of an Advance Rumely Oil Pull model F tractor with single cylinder engine. Many videos of them on Youtube.
-Jeff
wahlengines.com
Old 04-29-2019, 10:01:53 PM
Thx now I know what to look for (Rumely) I did not see any like this on YouTube but will keep searching for more information on the ignition system. As I’m not sure on what I will need to do to complete it. I also have my JD hit and miss 1930 I rebuilt it a few years back I use Colman fuel to run it. Not sure what fuel to use on this unit.
Old 04-29-2019, 10:19:03 PM
Jeff Wahl's Avatar
It is definitely a home made one of a kind model of an original Rumely tractor. You won't find another model like it. I referenced youtube in case you wanted to see the real thing your model was built after.
-Jeff
wahlengines.com
Old 04-29-2019, 10:44:34 PM
OTTO-Sawyer's Avatar
To answer your first question, yes, you should be able to use a car coil & condenser on it. I ran a car coil on my old Allis Chalmers Garden Tractor for several years and as far as I know it still running with it (I sold it a while back).
As for the John Deere "E" engine, unleaded Pump Gas works just fine. A lot of people complain about Ethanol Fuels, but personally, I've Never had any problems with it. BOTH Fuels were in use in the 1930s when they were built.
Old 04-30-2019, 01:06:17 AM
Harry's Avatar
You may need a resistor in series with the coil. Quite likely if yours burned out, it was designed for 6 volts.
(See our Terms of Service)
Old 04-30-2019, 07:47:56 AM
BMyrkle's Avatar
BMyrkle BMyrkle is offline
That is an extremely cool model. Please post a video of it running/driving when you get it going!
Old 04-30-2019, 08:27:29 AM
ronm ronm is offline
Google Modelectric coil. Used on model planes, takes up a lot less space and operates on 3 volts, as I remember.
Smokstak member #442
The Following User Says Thank You to ronm For This Post:
Old 04-30-2019, 04:06:19 PM
Thx all this really helps!
Ctmouse
Old 05-18-2019, 02:08:43 PM
Update, Ordered the CDI from Roy the motor appears to have good spark and the compression is there also But I'm not having much luck getting it to fire I did get a small pop a few times only. I'm using coleman fuel at this time maybe not a good choice? not sure? any ideals out there on what I should be looking at? the timing seams to be firing at TDC also I'm using the the points with the new ignition system.
thx Rick
Cushman Model 21 Type X (mag fired) Timing and Ignition Parts needed. KubotaDiesel Hit & Miss Gas Engine Discussion 2 10-13-2016 06:02:59 PM
Executive Model Design, Liney Machine, Mini casting's, Mini steam John Davis Scale Model Engineering 0 01-03-2016 01:33:43 PM
Starter rod needed for IHC model C tractor oeisales Antique Farm Tractors 1 03-02-2014 08:06:50 PM
J. Deere model E ignition help needed larryjoe Magnetos, Ignition Coils and Spark Plugs 2 12-09-2009 08:32:33 PM
Model Engine Ignition-Advice needed GarryB Hit & Miss Gas Engine Discussion 1 02-06-2005 04:22:37 PM
