Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
Adding a Feed PUMP to a Toy Steam Engine
this thread has 4 replies and has been viewed 427 times
Old 05-16-2019, 09:34:33 PM
Spenser Rynne Spenser Rynne is offline
Default Adding a Feed PUMP to a Toy Steam Engine
Hello, all. Working on some displays for the up and coming show season, and decided to rig up a generator to run a few of my old steamers. Currently a Jensen and an old Empire B-30, both electric heat engines. I have a Weilsco D-21 on a large table top setup, which was fitted with a gas burner and came from the factory with a boiler hand pump.
Frankly, I prefer my older engines over the Weilsco, since for one, it isn't old. And it just doesn't run as nice as the others. Also, it doesn't fire well outdoors.
Anyway, what I think I'd like to do is set up a feed pump on at least one of the older engines. The Empire even has a blanked off fitting that I think could be used for a water line. I'm more of a gas engine person and not too awful schooled on steam. A search online so far has brought back nothing. Weilsco doesn't sell a separate pump, even as parts, for my engine. If I had provisions, I'd machine one myself.
Has anyone ever done such a thing?
Old 05-17-2019, 10:06:33 AM
JBS JBS is offline
Default Re: Adding a Feed PUMP to a Toy Steam Engine
How about using as small car master cylinder with a one way check valve on it where the brake line come out and the other end of the check valve hooks up to the boiler.you would need to make a hand leaver to pump the water into the boiler.
Old 05-17-2019, 05:18:55 PM
b7100 b7100 is offline
Any small hydraulic or air cylinder can be used as a pump. Only need a lever to activate it and 2 check valves. One for inlet one for outlet.
Old 05-17-2019, 09:58:27 PM
Spenser: This might be what you want, unmachined .
https://www.ministeam.com/cgi-bin/sh...2ehtml#SID=436
They also have a machined one .
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
Old 05-22-2019, 06:22:44 AM
Trying to help on the cheap , but got no response, so try this one out
https://www.ebay.com/itm/223525555133?ul_noapp=true
Adding a Boiler Feed Pump? Spenser Rynne Vintage Toy Steam Engines and Motors 1 05-19-2019 05:52:42 AM
Small Old Steam Boiler Feed Water Pump Gil Garceau Steam Stationary Engines, Traction Engines 6 08-10-2018 09:46:59 PM
1912 Russell Steam Feed Pump Question mslisaj Steam Stationary Engines, Traction Engines 13 09-25-2016 11:48:53 PM
Adding a water pump to a John Deere G Johnny D 1837 Antique Farm Tractors 3 02-24-2016 11:28:07 PM
Adding an inline electric fuel pump D Behnke Antique Autos and Trucks 6 01-02-2011 01:41:35 PM
