Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
Cheap CDI Ignition Unit
this thread has 5 replies and has been viewed 4996 times
Old 11-18-2012, 02:54:50 PM
niceonetidy niceonetidy is offline
Default Cheap CDI Ignition Unit
Well chaps, I have looked for a cheap reliable, small compact ignition system for petrol ic engines. And so far, this is the bet I have found. . . . . . .
http://www.hobbyking.com/hobbyking/s...C_Engines.html
$20 for a complete system including the hall sensor. And they have twin cylinder versus too for another ten dollars. This unit will output three sparks In Quick succession. I have one here and its going on a friends cnc made engine. I will let you know how it goes. This unit make a big spark !
Happy days ?,
Cheers
Colin
The Following 2 Users Say Thank You to niceonetidy For This Post:
Old 11-20-2012, 08:32:52 AM
GeneratorGus's Avatar
GeneratorGus GeneratorGus is offline
Default Re: Cheap CDI ignition unit
Colin, they're getting cheaper, I paid about $30 for mine. It worked pretty good until I accidentally burned it out when my engine ground came loose.
I replaced it with an S&S kit at $40 I bought it at Cabin Fever last winter. Fairly easy to assemble and it doesn't seem to mind an occasional loss of ground, although I would not recommend being careless about keeping an eye on your engine grounded properly.
Don't forget, for slow running models you'll need about 20 degrees additional spark advance with the Hobby King ignition.
GUS
Old 11-20-2012, 01:35:46 PM
DustyBar DustyBar is offline
Originally Posted by GeneratorGus View Post
...with an S&S kit at $40 I bought it at Cabin Fever last winter...
What is S&S and is the kit available by mail order?
Old 11-23-2012, 02:01:37 PM
CaptainJohn CaptainJohn is offline
Take a look at the Black Box ignition, it has a better spark and is made here in USA and can be serviced. I have read about CD ignitions for years & kept up with what small CD ignitions are the best. I will post a link to the video & data. Capt,n
---------- Post added at 12:57 PM ---------- Previous post was at 12:50 PM ----------
Hear is the video of the Black box ignition.
https://picasaweb.google.com/1106774...09599272854050
---------- Post added at 01:01 PM ---------- Previous post was at 12:57 PM ----------
Here is the address for the Guy that builds & repairs the Black Box CD ignition. This ignition uses the same circuit of one of the best units that has been around for may years.
John Weidman
341 Ontelaunee Trail
Hamburg, Pa. 19526
Old 11-23-2012, 03:17:47 PM
Dave Otto Dave Otto is offline
Here is the link to the S&S ignitions; they are not cheap but work quite well; and I believe they are also US made.
http://www.cncengines.com/
Dave
Old 06-27-2019, 05:19:46 PM
Tim Venetis Tim Venetis is offline
Dave
The email for John Weidman does not work
gr8flyer55@verizon.net
Cheap Electronic Ignition UpGrade... By requests bobbyz72 Onan Generators 28 05-07-2017 09:03:21 PM
Honda Eu3000is ignition unit burning up HELP Tomvoegt Honda, Yamaha, Kawasaki, Isuszu Generators 4 01-25-2017 01:58:20 AM
Cheap And Simple Electronic Ignition Circuit Elden DuRand Hit & Miss Gas Engine Discussion 29 02-20-2016 08:18:31 AM
Cheap ignition upgrade? bobbyz72 Onan Generators 2 02-16-2010 11:08:02 PM
Generator/Starter/Ignition unit Adam Cottrill Antique Engine Archives 3 10-29-2003 02:28:37 AM
