Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
1/2 size KC Lightning tractor
this thread has 15 replies and has been viewed 1152 times
Old 07-27-2019, 08:40:43 AM
Marv in Minn's Avatar
Marv in Minn Marv in Minn is online now
Default 1/2 size KC Lightning tractor
back in the '90's i had built a 1/4 Kansas City Hay Press Lightning Engine
by measuring the full size engine that Morris Blomgren had.
in my research of those engines i kept seeing ads for a KC tractor.
Morris' engine is on a taller cart that looks a lot like the tractor frame.
about 2 years ago i started drawing, making patterns and building a 1/2 size.
yesterday it came to life!
https://youtu.be/KnwSCngzWr0
i still have some work to do on the friction drive.
ID:	340065   Click image for larger version
ID:	340066   Click image for larger version
ID:	340067   Click image for larger version
ID:	340069   Click image for larger version
ID:	340070   Click image for larger version
restoring old iron, hot air engines and modelmaker.
Old 07-27-2019, 08:44:51 AM
Default Re: 1/2 size KC Lightning tractor
Morris' engine that i am the current caretaker of.
ID:	340072   Click image for larger version
Name:	marv and lightning.jpg
ID:	340073   Click image for larger version
ID:	340074   Click image for larger version
ID:	340075   Click image for larger version
The Following 8 Users Say Thank You to Marv in Minn For This Post:
Old 07-27-2019, 10:09:20 AM
Nick's Avatar
Nick Nick is offline
That is some absolutely beautiful work!
The Following User Says Thank You to Nick For This Post:
Old 07-27-2019, 11:15:15 AM
LCJudge LCJudge is offline
Marv, so glad you've almost got my tractor done...........
Beautiful work, as always.
How close are the dimensions on your engine to my 6 HP? Probably a bit closer to the 4 HP parts engine I have? I've thought building a tractor out of the big KC Lightning would be a fun project (I've always said its a 12 HP but since there is no HP stamped on it, I'm not sure). But, it would take a LOT of work to build the frame, wheels, gearing, clutch mechanism, etc, etc. I've got too many other projects to try to tackle something like that!
Tommy Turner
The Following 2 Users Say Thank You to LCJudge For This Post:
Old 07-27-2019, 11:24:41 AM
half size of the 10 hp = 3 1/2" pistons, 20" flywheels
The Following 3 Users Say Thank You to Marv in Minn For This Post:
Old 07-27-2019, 10:04:32 PM
OTTO-Sawyer's Avatar
Photo Re: 1/2 size KC Lightning tractor
I've shared this before in a couple other threads, but it kind of fits here too.
From a 1908 KC Haypress Brochure that showed up on eBay several years ago.
Name:	1908 Kansas City Hay Press Company  Tractor.jpg
Old 07-27-2019, 10:40:30 PM
Fantastic job
The Following User Says Thank You to casertractor For This Post:
Old 07-27-2019, 11:12:40 PM
that's the other ad i worked from.
thanks, Marv
The Following User Says Thank You to Marv in Minn For This Post:
Old 07-28-2019, 02:14:33 AM
JasonB JasonB is offline
Very nice, I hope you are going to keep that patina as it looks the part rather than a bright fresh paint job.
The Following User Says Thank You to JasonB For This Post:
Old 09-09-2019, 05:00:35 AM
running together for the first time
https://youtu.be/5VNeoLfbAEc
Name:	Lightnings together.jpg
Old 09-09-2019, 03:04:24 PM
J ohn J ohn is offline
Congrats on Fine Project, Marv > Here are few more images taken Little Log House Show at 1st startup. The builder is photo shooting his fine work.
Many Thanks to Your labors !!
ID:	343590   Click image for larger version
ID:	343591   Click image for larger version
The Following 7 Users Say Thank You to J ohn For This Post:
Old 09-09-2019, 10:22:20 PM
we belted it for the first startup but have hand started it after that
The Following 5 Users Say Thank You to Marv in Minn For This Post:
Old 09-30-2019, 10:08:47 AM
https://www.youtube.com/watch?v=UFI6...em-uploademail
Old 09-30-2019, 11:43:28 AM
Tim Colwell's Avatar
Tim Colwell Tim Colwell is offline
Any chance you could get some more pics of the gearing and how the clutch works?
Tim Colwell
JD & IHC corn sheller and engine collector.
Old 09-30-2019, 12:55:48 PM
plan B work in process, i will update when working
Old 09-30-2019, 05:44:10 PM
Sounds good, can't wait to see this on the show circuit next year!!
Tim Colwell
Found Minneapolis parts - what size tractor? Rob Bryce Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 11-08-2013 01:35:53 AM
Onan MCCK oil drain plug size and oil pressure port size? sdowney717 Onan Generators 2 04-17-2012 05:50:55 PM
IHC Tractor What Size? John Davidson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 10-29-2011 08:13:19 AM
Huber steam tractor what size is it steve hujber Steam Stationary Engines, Traction Engines 5 05-04-2009 11:08:15 PM
Full size tractor Weather Vain... JKWidener Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 05-06-2007 03:40:52 AM
