Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
Model of American La France Steam Fire Engine
this thread has 280 replies and has been viewed 64274 times
Old 03-08-2018, 10:34:16 PM
Craig DeShong's Avatar
Craig DeShong Craig DeShong is offline
Default Re: Model of American La France Steam Fire Engine
I used to see Larry quite a bit when he lived here in the Raleigh area. The last time I stopped by to see him, some time ago, he had put the La France on the shelf and his attention was elsewhere.
Since then Larry has moved out of the area, I think somewhere in Maryland? And I've lost touch with him. I just checked and He hasn't logged in to Smokstak for two years.
Still, I too hope his attention returns to this project. His work is just fantastic an I too would like to see this project finished.
[I]My Photos
Old 03-08-2018, 10:55:14 PM
Charlie1925 Charlie1925 is offline
Check post 217 and see this project mostly complete, with only the pump to complete, I too hope Larry is still with us, but it dose not sound good , Can only hope for the best. Maybe Harry would know.
Old 02-16-2019, 09:32:56 AM
MarkBillesbach's Avatar
MarkBillesbach MarkBillesbach is offline
It's been almost a year since this post was brought up, but I still am curious as to what became of Larry and his beautiful scale model. Has anyone heard anything about him?
Old 03-11-2019, 08:23:31 AM
CoalBurner CoalBurner is offline
Several years ago, I acquired a partially-completed Coles fire engine. Since this item is nearly a basket case, I'm curious about others who may be building one at this time. Hopefully, I may be able to tap into their knowledge of how this thing goes back together. (?)
Neil
The Following 2 Users Say Thank You to CoalBurner For This Post:
  #265
Old 03-15-2019, 04:33:54 PM
chrsbrbnk chrsbrbnk is offline
I tried emailing him a few days ago and haven't heard back yet , but my email address for him is a few years old
Old 07-12-2019, 12:27:58 AM
Case Place Case Place is offline
Greetings my fellow model makers. Thank you for your concern about my well being. It has been a rough 5years, but things are settling down and somewhat normal, if there is such a thing. My wife and I left NC 4 years ago this coming Christmas.. we moved to Stuart, VA. We are about 4 miles from our daughter and 2 grandsons. It has been only within the last few weeks that I have become motivated to do any model work. Hence this posting ! Right now, I am finishing up a “Tiny Power” rope engine that my father started a long time ago. I am in the final stages of assembly. Pictures to come soon. Then I plan to get back to the LaFrance project.. Again, thank you all for my concern. Larry
Larry
The Following 8 Users Say Thank You to Case Place For This Post:
  #267
Old 07-12-2019, 09:46:46 PM
b7100 b7100 is offline
Welcome back to the stak. There are a ton of people that would like to see you back on track with the lefrance
The Following User Says Thank You to b7100 For This Post:
  #268
Old 07-13-2019, 10:49:04 PM
Thank you to all for the welcome back to Stak. The LaFrance project is sitting on the bench with a cover over it. I promised myself to finish up a model that I inherited from my father before I get back to the LaFrance project. It is a Tiny Power Rope Engine. It has been great to get back to my model making.
When we moved to Virginia, I had a 30’x30’ concrete block barn to to put my shop in. It use to be a horse barn. It turned out the area I wanted to use for my shop was the dirt floor area that was the horse stall. I spent a good 6 months pouring concrete, wiring, painting and moving all my machinery from Cary, NC to our new residence in Virginia. The machine shop is 10’x30’. Sounds small, but actually very comfortable for a one man shop.
The first two pictures are of my machine shop. The next two are of the Rope Engine present status.
ID:	339008   Click image for larger version
ID:	339009   Click image for larger version
ID:	339010   Click image for larger version
Larry
The Following 10 Users Say Thank You to Case Place For This Post:
  #269
Old 07-14-2019, 05:45:54 PM
Strung the rope or in this case 20’ of 3/32” diameter rubber O-ring on the model. Used Superglue for joining the ends together.
ID:	339066   Click image for larger version
ID:	339067   Click image for larger version
Larry
The Following 5 Users Say Thank You to Case Place For This Post:
  #270
Old 07-15-2019, 06:47:40 AM
QuickJ QuickJ is offline
This looks awesome.
The Following User Says Thank You to QuickJ For This Post:
  #271
Old 07-15-2019, 11:59:02 AM
J Dayman J Dayman is offline
Great to see you back Larry / Case Place. Beautiful rope drive mill engine model. Shop looks great too.
The Following User Says Thank You to J Dayman For This Post:
  #272
Old 07-15-2019, 11:53:22 PM
Many years ago, I purchased a Stuart governor kit to go with the Rope Engine. I figured if it would work on the Stuart twin Victoria, it should handle the Rope Engine. Below is a picture of what I have done thus far. The governor is interesting that it controls two steam inlet valves, one for each cylinder. Mounting two separate valves atop each steam chest, having a common linkage between them and then linked to the governor, should be a nice challenge.
Larry
The Following 4 Users Say Thank You to Case Place For This Post:
  #273
Old 07-16-2019, 05:06:46 PM
OTTO-Sawyer's Avatar
Good To See You Back and At It Again.
Looking Forward to Many More Posts From You.
  #274
Old 07-18-2019, 09:58:58 AM
Greetings, spent last evening working up one of two throttling valves for the rope engines. A piece of extruded brass came with the governor kit, but it is so large, it just wouldn’t look right. So, I struck out on my own and came up with what see in the pictures. Basically I machinery up 3 pieces of brass and soldered them together, then machined the assembly as if it were a casting. Still need to machine the valve stem gland and nut.
ID:	339304   Click image for larger version
ID:	339305   Click image for larger version
ID:	339306   Click image for larger version
Larry
The Following 3 Users Say Thank You to Case Place For This Post:
  #275
Old 07-21-2019, 12:17:19 AM
Good evening. First I would like apologize for high jacking my own thread with the Rope Engine. I should have started a new thread for it. Anyway, I finished making all the necessary parts for the engine this evening. Need to order some plumbing fittings and tubing. Meanwhile I will disassemble, paint, polish and generate some clearances where need be. I tend to build tight, then loosen things up at a later date. In the background of picture 2 you can see what I have my sights on for my next project. Yes !! LaFrance here we come.
ID:	339539   Click image for larger version
ID:	339540   Click image for larger version
ID:	339541   Click image for larger version
Larry
The Following 7 Users Say Thank You to Case Place For This Post:
  #276
Old 07-22-2019, 06:30:19 PM
Nice to hear from you again Larry, glad you have some time to spend in the shop.
[I]My Photos
The Following User Says Thank You to Craig DeShong For This Post:
  #277
Old 08-05-2019, 10:08:57 PM
Welcome back Larry, I missed your work, I've been following the American La France from the start. I can't wait to see both projects completed.
Old 09-11-2019, 11:13:02 PM
Greetings, the Rope Engine is finished and running very well. I went from O-ring cord material to cotton string with a square knot to join the ends together for the “belt”. Could not upload a video showing the engine running. In the picture of the Rope Engine you can see some of the LaFrance parts in the background. The LaFrance steam cylinders and pump assembly has been dismantled. The second picture shows a jig I made to assemble the steam cylinders and pump assembly without working in and around the chassis.
ID:	343816   Click image for larger version
Larry
  #279
Old 09-21-2019, 12:25:12 AM
Good evening my fellow modelers. I have spent many hours this past week assembling and aligning the steam cylinders, pistons, connecting rods, pump piston yokes, water pump pistons and connecting rods, water pump cylinder block and crank shaft middle support bearing. It all finally came together this evening. The flywheels rotate very nicely. I am very pleased. 😉 As you can see in the pictures, it is quite crowded between the steam engine mounting plate and the top of the pump block. The eccentric mechanism for both steam cylinders still need to fit In amongst all this.
I am planning to work on the steam exhaust manifold next and work my way down towards the eccentrics.
ID:	344559   Click image for larger version
ID:	344560   Click image for larger version
Larry
  #280
Old 09-23-2019, 07:11:14 PM
Larry:
Nice to see you're back on the fire engine project! Your comments and photos regarding the "test stand" for the engine/pump mechanisms are really timely. Several years ago, I acquired a partially completed LaFrance, and wondered just what would be the best setup to assemble those components. I'll use your idea. Thanks!
Neil
1863 Amoskeag steam fire engine on ebay.. Davide L. Steam Stationary Engines, Traction Engines 7 01-08-2012 02:21:59 PM
Steam Fire Engine Pic's - Natchez, Mississippi Mike Grivna Steam Stationary Engines, Traction Engines 4 05-15-2011 11:56:33 AM
It's Alive! (American La France V-12 ) Andrew Mackey Antique Autos and Trucks 7 07-18-2009 09:58:02 AM
1951 American La-France V-12 Andrew Mackey Antique Autos and Trucks 12 03-16-2009 08:28:38 AM
Trial of the Steam Fire Engine Report - 1876 Mark Antique Engine Archives 0 03-10-2000 12:43:03 PM
