Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
1/3 Scale Case Boiler
this thread has 500 replies and has been viewed 68592 times
Old 05-19-2019, 07:53:34 PM
b7100 b7100 is offline
Default Re: 1/3 Scale Case Boiler
So how come you are fireing up in the rain when it's 65 degrees with a cold boiler and cold city water and crap half wet wood? It must be my age but I try to avoid those conditions. An hour and 25 minutes to get 90# of steam! Are you trying to make me feel good? Susshine tomorrow I'll try it then.
The Following User Says Thank You to b7100 For This Post:
Old 05-20-2019, 11:39:52 AM
oldiesteam's Avatar
oldiesteam oldiesteam is offline
Well it was sunny when I lit the fire then poured rain for twenty minutes got a good solid hour of running around the yard with it and fan time before you started raining again. Figured it needed to be out and cleaned as well since it hasn't been looked at since August last year.
The Following User Says Thank You to oldiesteam For This Post:
  #483
Old 05-20-2019, 11:49:01 AM
You need to concentrate more on your steam division and less on your hit and miss division. (Or) change your name to Oldiesgas. Or maybe Gotgas.
  #484
Old 06-07-2019, 11:58:35 AM
Weighed it today. 1260# with boiler and bunker topped off.
---------- Post added at 11:58:35 AM ---------- Previous post was at 11:47:17 AM ----------
Weighed it today. 1260# with boiler and bunker topped off with water. Thought it would be more than that. Was thinking Oldies steam said 1500# for his. I wasn't sitting on mine when I weighed it.
The Following 2 Users Say Thank You to b7100 For This Post:
  #485
Old 06-09-2019, 02:13:03 PM
What is a quality steam gauge that holds up well? I have one with the Case logo on it that I think I paid $80 for. (Cheap gauge with Case printed on the dial). It is sticking.
Old 06-10-2019, 01:22:01 PM
oldiesteam's Avatar
I think it was about 1200# when I weighted mine but I wasn't on it and bunkers were empty.
As far as a steam gauge goes not sure I can help you there. Mine's OLD but was going to retire it and get one with the name printed in it like yours never have.
  #487
Old 06-10-2019, 04:05:02 PM
Weight sounds about right. I think there is 15-20 gallons water. I am gioing go try to disassemble the gauge and see if I can get a little oil in it and loosen it up a bit. Worked fine last year. Zero experience with gauges (so far)
Old 06-10-2019, 11:20:47 PM
butch vollmar butch vollmar is offline
7100 -- Check out Mc Master-Car.
The Following User Says Thank You to butch vollmar For This Post:
  #489
Old 06-11-2019, 07:13:48 AM
Checked out Mcmasters Carr. One (steam gauge)was $35. But it was 3 1/4" diameter. Not a good fit. Another (high temperature gauge) was $250 to almost $800. Don't need that. There has to be a 2" steam rated gauge reasonably priced. I'll keep looking or try to get this one working.
Old 06-11-2019, 10:02:51 AM
1/4case 1/4case is offline
We use Wiki glycerin filled gauges here. Seem to hold up well and the liquid fill keeps them from jumping around. Brass bodied and real glass fronts. PM me an address and Ill send ya one.
The Following 2 Users Say Thank You to 1/4case For This Post:
  #491
Old 06-12-2019, 12:37:28 PM
skugger skugger is offline
an acquaintance of mine owns a machine shop that makes parts for the 7 1/2 inch gauge locomotive hobby. He has a steam pressure gauge that might be the size you want, maybe a little small. http://locoparts.biz/parts.html#Gauges
The Following 2 Users Say Thank You to skugger For This Post:
  #492
Old 06-12-2019, 02:10:51 PM
Thanks Skugger. I am going to see what 1/4 Case comes up with. I looked at the website and it is a little small. The Wika gauges seem to be more to an industrial standard. Brass construction with real glass. I'll see how they hold up. Hopefully I can get things like this sorted out so others won't waist resources on junk.
Old 06-13-2019, 11:48:22 AM
chrsbrbnk chrsbrbnk is offline
a little size to the gauge doesn't hurt , your going to want to sit down for lunch ,or be building steam with blower on, or gathering fuel for some task or be off the engine for some reason , and your going to need to see your pressure form 10 to 20 feet away. a decent size pressure gauge and a decent size water column glass are critical to safety a nice 2 1/2 inch gauge works you want the normal pressure you run to be about straight up on the gauge and put a gauge siphon tube on (pigtail) it
The Following User Says Thank You to chrsbrbnk For This Post:
  #494
Old 06-13-2019, 01:47:33 PM
oldiesteam's Avatar
Did you contact the guy you got the gauge from? I thought he was using Ashcroft Gauges to begin with. Also you might need to change your gauge line to a pig tail instead of the U shape your running.
  #495
Old 06-13-2019, 02:36:22 PM
No I did not contact the guy I got it from. His website doesn't state that they are ashcroft gauges. He does have a rebuild service for antique gauges. I am not an expert of quality gauges so to call his gauges junk may be a bit unfare. I do know that it lasted a year - now it's sticking. Maybe there is a reason. The Wika gauge seems to be a quality comercial gauge. It is 2 1/2" diameter. Not sure what a pigtail is. I thought you needed a syphon to protect the gauge. The old gauge is 2 1/2" so fit isn't an issue.
Old 06-13-2019, 02:55:22 PM
Pete LaBelle Pete LaBelle is offline
Hey B7100 -
Gauges should not be lubricated. They should run dry.
True steam tractor gauges have a double Bourdon tube, and due to the linkage, nullify any backlash in the gears, thus, remain steady on a vibrating steam tractor. Standard gauges do not. Mounting your gauge to a vibrating machine or pipe that jiggles agrevates the gauge.
Liquid filled gauges were designed for high vibration applications. Not sure how well they'd hold up above a hot boiler though.
As long as gauge materials can handle the heat (housing, face, glass, bronze innards), it'll work fine on your engine.
The challenge these days is trying to find one with only pounds on it, and not also a Metric equivlant.
Keep looking...
Pete
The Following User Says Thank You to Pete LaBelle For This Post:
  #497
Old 06-14-2019, 01:53:09 PM
mcmaster pigtail 1/4 4" 240 psi @ 400° F ASTM B43 4031K28 8.40
  #498
Old 06-14-2019, 09:33:31 PM
O.K. I get the pigtail. Is that to mean that the gauge was getting too hot causing it to malfunction? The pigtail will insulate better from heat damage!
Old 08-07-2019, 08:01:49 PM
Going to be at Buckley next Friday thru Sunday. Hope to see a lot of models there.
Old 09-28-2019, 11:30:44 PM
Had a busy day. Pictures are in front of Henry Ford's boyhood home at Greenfield Village. This was the 18th event this year. Other pictures were at Amish Acres - Napanee, Indiana last week.
ID:	345289   Click image for larger version
ID:	345290   Click image for larger version
ID:	345291   Click image for larger version
The Following 6 Users Say Thank You to b7100 For This Post:
boiler feed pump for scale Case TomBall Steam Stationary Engines, Traction Engines 4 12-28-2013 06:41:51 PM
Where to have a boiler built or find one for a 1/2 scale 65 case. jbott82 Scale Model Engineering 10 11-20-2013 12:45:15 PM
2in scale Case 65 hp boiler barrel asc31 Steam Stationary Engines, Traction Engines 4 09-13-2013 04:25:56 PM
Case 1/2 scale gets new Boiler Langes Machine Shop Steam Stationary Engines, Traction Engines 10 03-08-2012 06:31:00 PM
Steel for 1/3 scale Case boiler chrsbrbnk Scale Model Engineering 1 09-29-2010 10:09:03 PM
