Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
Max Distance Displacement Oiler to Engine
this thread has 2 replies and has been viewed 400 times
Old 05-16-2019, 05:45:29 PM
adamlund adamlund is offline
Default Max Distance Displacement Oiler to Engine
Is there a maximum distance a displacement oiler can be from the engine, or can it go anywhere in the steam line before the engine
Old 05-16-2019, 11:56:44 PM
Richard Miller Richard Miller is offline
Default Re: Max distance displacement oiler to engine
Instructions for installing double connection Detroit Lubricator, from 1912 edition of the Detroit Lubricator Co.
Name:	for sale 008.jpg
The Following User Says Thank You to Richard Miller For This Post:
Old 05-19-2019, 11:46:46 AM
gbritnell gbritnell is offline
Default Re: Max Distance Displacement Oiler to Engine
I am starting with the obvious. The displacement oiler work this way. As live steam enters the oiler it condenses to water and sinks to the bottom of the oiler (heavier than oil) Now it does what it is called, it displaces the oil with water and the oil flows out into the steam line. I don't know if there is an exact number that you are looking for but I would assume that if it were placed anywhere along the steam supply line it would provide oil to the cylinder and valve of the engine.
gbritnell
The Following 2 Users Say Thank You to gbritnell For This Post:
Old Shorpy pic with engine builder in the distance Brian Lynch Antique Marine Engines and Outboard Motors 1 08-18-2015 11:16:17 PM
Engine Displacement Formula Rene Elliott Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 11 11-08-2009 06:00:13 PM
Calculating horsepower based on engine displacement? Jerry Christiansen Hit & Miss Gas Engine Discussion 6 12-14-2007 10:27:51 AM
Lunk Jr. Displacement Oiler Rick Strobel Steam Stationary Engines, Traction Engines 0 01-24-2006 12:38:22 PM
Displacement oiler glass tube Rick Strobel Steam Stationary Engines, Traction Engines 11 10-19-2005 09:43:23 AM
