Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
Need rings for a Fairbanks engine
this thread has 2 replies and has been viewed 396 times
Old 07-07-2019, 06:47:16 PM
Ronald E. McClellan Ronald E. McClellan is online now
Default Need rings for a Fairbanks engine
I have a model of a Fairbanks Morse 1A Eclipse engine. I bought it some time ago. It looks great but has zero compression. It looks like it was never run. I finally took it apart and found that the top ring is missing. Even with one ring you would think that it would have a little compression , but no. Is someone still making this model? Where can I get rings? The piston is 1 1/2" , the bore is a little over size. the ring is 1 1/2"+ X .093" high X .065" wide. Ron
The Following User Says Thank You to Ronald E. McClellan For This Post:
Old 07-07-2019, 07:06:02 PM
Heller D. Davis Heller D. Davis is offline
Default Re: Need rings for a Fairbanks engine
Ron, Starbolt carries rings for model engines. He is a subscriber here.
The Following 2 Users Say Thank You to Heller D. Davis For This Post:
Old 07-07-2019, 07:16:10 PM
www.starboltenginesupplies.com
The Following 2 Users Say Thank You to casertractor For This Post:
Piston rings for Fairbanks Morse z headless Engine Antiquengine Hit & Miss Gas Engine Discussion 3 12-28-2016 01:29:14 PM
Fairbanks Eclipse Rings Mark K Hit & Miss Gas Engine Discussion 2 07-16-2014 08:16:38 AM
Fairbanks 1.5 dishpan odd rings? Jamie Darian Brown Hit & Miss Gas Engine Discussion 1 12-11-2011 01:02:29 AM
AB33 & Fairbanks F1 Magneto Collector Rings Andrew Albrecht Magnetos, Ignition Coils and Spark Plugs 0 09-09-2006 06:40:28 PM
Fairbanks piston rings GM16 Antique Engine Archives 4 06-01-2004 09:40:26 PM
