Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
Witte model- 2" Piston drawing needed
this thread has 0 replies and has been viewed 274 times
Old 07-30-2019, 11:42:46 AM
PaulGray's Avatar
PaulGray PaulGray is offline
Default Witte model- 2" Piston drawing needed
Have a friend who has one of the headless Witte model engines with a 2" bore. It has waaaaaayyy too much compression and I want to make him a modified piston to drop the CR. Apparently there are two versions of the piston made; one lower CR and one higher. I want to go even lower than either of these. If someone can scan the piston drawing (only) from existing plans, I'd sure appreciate it. you can either post it or PM me.
Baker Monitor VJ 1.25Hp piston drawing Joe Aletto Hit & Miss Gas Engine Discussion 0 07-22-2019 08:29:53 PM
Baker Monitor 1.25Hp piston drawing Joe Aletto Hit & Miss Gas Engine Discussion 0 07-22-2019 06:48:54 PM
3-9/16" piston advice needed PaulGray Hit & Miss Gas Engine Discussion 3 09-14-2010 06:40:18 PM
Witte 3HP "B" info needed Jim Sherman Antique Engine Archives 0 09-26-2004 10:27:58 AM
WITTE MODEL "J" OIL LEVEL TOM Antique Engine Archives 0 02-24-2001 06:28:47 PM
