Welding Shop
Identify Old Welding End
this thread has 8 replies and has been viewed 630 times
Old 06-01-2019, 07:28:13 AM
DJB6.03CE DJB6.03CE is offline
Default Identify Old Welding End
Hoping someone knows what make this is, no tag on the unit, mounted on a Wisconsin THD around the 50s
Part numbers all start with a G
G29-328 brush part number
G26-34
G29-285
https://flic.kr/p/2g6EA9E
https://flic.kr/p/2g6ER8a
https://flic.kr/p/2g6ER4h
Old 06-01-2019, 03:30:33 PM
Default Re: Identify Old Welding End
Looks like an aircraft starter or generator.
Old 06-01-2019, 04:40:03 PM
By end I thought welding rod or stinger...
Agreed, looks like an aircraft starter generator.
That flicker is terrible. Fuzzy little pictures. Can you upload here? Does the generator have a nameplate on it anywhere?
I have a big one that actually came off of a tank or some such thing...
https://www.smokstak.com/forum/showthread.php?t=179628
Old 06-04-2019, 11:19:42 PM
dkamp dkamp is offline
eMail NOT Working
That's a 28v aircraft generator. Off the top of my head, Hobart made some, but lots of other companies contracted to manufacture those, there were some for sale at Surplus Center couple-five years ago or so. They push enough current and voltage (unregulated) to weld... but they'll also do a fine job as an engine starting unit...
..trying to remember the biggest manufacturer's name... two words, hyphenated...
Ah... Delco-Remy... there was a variety of 'em, and I think they showed up on everything from radial engines to turbofans. I'm not certain wether they used them for starting motors AND generators, but they probably could have...
Old 06-05-2019, 12:59:42 AM
Many are starter generators. Mine is not, but will run fine as a shunt motor... Just doesn't have the series winding to give the grunt equal to amps squared.
Old 06-05-2019, 05:54:04 PM
Tracy T Tracy T is offline
delco in fact did both, although smaller than what the OP has. I have seen them on older model kohler & briggs engines and also on the later modle IH cub tractor. all of these were the size of a automobile generator and they must put out some torque to be able to spin the flathead 4 in a cub tractor!
Old 06-07-2019, 06:28:24 PM
eMail NOT Working
You are very correct on this, Tracy- all my older IH Cub Cadet garden tractors (prior to 1978 or so) have Kohler K-singles with starter-generators... and they will do both...
.. they do both, equally as bad... On a cold day, it's all that poor thing can do to lunk over the one-lung 12hp and hydrostat.
The IH Cub Lo-Boy used one on it's C60 four-cylinder too... I had a Cub 154 that used starter-generator, rather than ring-gear, and it actually cranked it better than my single-cyl Kohlers.
In a larger form factor, they probably work a little bit better...My Onan 5CCK used exciter start, as do my Kohler L600 and L645 four-cylinder liquid cooled spark-ignited fours... the biggest exciter-starteds of my herd are Kohlers with 4-cylinder Waukesha FC140's...
MIG Welding cobbadog Welding Shop 15 12-22-2017 07:16:57 AM
AC or AC/DC for Welding Shay 5 fan Welding Shop 8 01-18-2012 02:23:13 PM
Welding rod Chris J Welding Shop 7 08-17-2008 10:22:53 AM
Thoughts on crankshaft welding/ engine block welding Mac Leod Small Air Cooled Gasoline Engines 10 04-14-2008 10:46:02 PM
Welding Matt Fretwell Welding Shop 23 10-12-2003 07:35:59 AM
